GTi Cutting Out!!!
(In Topic #79566)
![cam80 in the usergroup ‘Regular’ cam80 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
GTi Cutting Out!!!
The previous owner thought it was the fuel pump relay, so i hav been reseating the relays to try an restart. This doesn't always cure the problem tho.
I think it may be a mk2 fuse box i have (not sure if the Gti has the same as a mk2 or not?). Does anyone know which relay is the fuel pump relay?
Or any other faults which may be causing the car to cut out?
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
Any help would be great
Cheers, Craig.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AvatarUploadedByTapatalk1451991667.jpg)
![volkswarren in the usergroup ‘Paid Member’ volkswarren in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![volkswarren in the usergroup ‘Local hero’ volkswarren in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
it may well be the pump that has failed. or less likely the coil breaking down.
Regards Volkswarren
![Avatar](https://i248.photobucket.com/albums/gg178/allsorts5/Mk1OCAvatar.jpg)
![allsorts in the usergroup ‘Local’ allsorts in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=10029&highlight=
Mk1 Golf GTI 83 Y reg in Lhasa green
Rear disc conversion
Lowered 20mm
14" Campaign Pirrelli P Slots
Lowered 20mm
I'll check these out this week, Fingers crossed its a simple fix
Craig
