wipers wont turn off!
(In Topic #79082)
![Avatar](https://i17.photobucket.com/albums/b56/optimusprimer/artav.jpg)
![optimusprimer in the usergroup ‘Regular’ optimusprimer in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
is it run from a relay in the fuse box area? if so which one is it so i can check it.
any ideas what it could be?
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Looks like it could be the self park switch in the motor . You no when you operate the intermittant wipe the wipers do one clean sweep then turn them selves off and go to the bottom of the screen ? Well if this fails they will stay on . The motor is supplied with a permanant live for this facility + it allows the wipers to self park at the base of the windsceen .
You may need to strip and clean the motor and the gear assembly . If its faulty a MK2 will provide a good replacement [search the forum for how] Furbers at Heapham has 2 in stock
Cheers Chudd………….
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AvatarUploadedByTapatalk1451991667.jpg)
![volkswarren in the usergroup ‘Paid Member’ volkswarren in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![volkswarren in the usergroup ‘Local hero’ volkswarren in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Regards Volkswarren
![Big in the usergroup ‘Regular’ Big in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Big
thats one bit fixed but leads to the bigger question of where is the leak?? turns out the front window rubber wasnt sat right! job done, thanks all
