part-way through renovation of underside
(In Topic #78749)
![](https://vwgolfmk1.org.uk/uploads/pbextract/652982/Dsc02322reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/652982/Dsc02323reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/652982/Dsc02324reduced.jpg)
More pics will be added soon…
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.golfmk1.co.uk%2Fimages%2FExLink%2FAvatar.jpg)
![crazyquiff in the usergroup ‘Paid Member’ crazyquiff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![crazyquiff in the usergroup ‘Paid Advertisers’ crazyquiff in the usergroup ‘Paid Advertisers’](https://vwgolfmk1.org.uk/themes/default/images_custom/PaidAdvertiserIcon.png)
![crazyquiff in the usergroup ‘Local hero’ crazyquiff in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Hairyarse said
Nice one, what did you coat the underside in? gotta do mine soon
Black stonechip, apparently its alkyd based and its a rubbery flexible paint which can be overpainted and lasts longer before flaking, than traditional underseal.
Hairyarse said
Looks tidy Paul. Any particular brand?
No particular brand, I just went for the one that my FLAPS has on the shelf.
Okay, now I've finished the underside areas, I can reveal the real area of concern. As can be seen, I have removed the seat back support panel to gain more access, and tomorrow I'll be cutting out the rusty areas and making up new ones to let in.
![](https://vwgolfmk1.org.uk/uploads/pbextract/653303/Dsc02332reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/653303/Dsc02334reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/653303/Dsc02343reduced.jpg)
![susan in the usergroup ‘Newbie’ susan in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
![](https://vwgolfmk1.org.uk/uploads/pbextract/653878/Dsc02349reduced.jpg)
![AUSGOLF in the usergroup ‘Regular’ AUSGOLF in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
What alerted you to the presence of the rust. The area is hidden under the seat back support and linings isn't it?
Paul
![Avatar](https://i65.photobucket.com/albums/h232/macca_photos/Granton009.jpg)
Secretary
![Macca in the usergroup ‘Paid Member’ Macca in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Macca in the usergroup ‘Regional Hosts’ Macca in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Macca in the usergroup ‘Old timer’ Macca in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Keep meaning to take some pictures and put on my own thread but always just seem to get carried away working on something else on the car.
Mark one did a similar job on his car an made a great job of it.
Maybe soon I will get around to taking the photos and post them. :roll:
AUSGOLF said
Paul,
Paul
Only some of the area is hidden, the rest was visible inside the boot. Once I'd stripped other items and trim away, I could see the extent of the rust, which has nearly all been cut out. I will make replacement panels to go into the cut away areas. I need to somehow fabricate a seat belt reel mounting point, though.
Secretary
Get a nut which is the same thread as the seat belt fixing bolt. drill a hole in the repair panel in the correct position for the seat belt holder (before welding the panel in) then weld the bolt to the rear, or inside of the repair panel. There you have it. :y:
Macca said
Paul
Any idea of the correct thread pitch? I know its an M10 (17mm) nut. I'll need a new bolt too, due to rusting of the original one. Aren't they corrosion-resistant too? Like a yellow coating?
Secretary
Macca
Macca said
I'm not sure at this time. As I said I have similar problems, but the fixing bolt for mine is okay. Will check tomorrow and let you know.
Macca
No worries, I forgot I can simply look at the other side to find out the thread! I know its a finer than usual one.
Secretary
Anyway keep us posted as how you get on. I will try and get the photos taken and start my own thread.
Off to bed now. Need my beauty sleep lol
Macca said
In fact is M10 not a standard thread size :dontknow:
M10 is the width of the bolt, but the thread could be 1.5mm (standard), 1.25mm or 1.00mm. I'll buy them off these guys:
http://www.namrick.co.uk/browse.asp?PCID=9
![](https://vwgolfmk1.org.uk/uploads/pbextract/654853/Dsc02355reduced.jpg)
The rest was done using a junior hacksaw, or grabbing the metal with pliers and wiggling back & forth until it snapped. I'll do my best to straighten out the remaining good metal, which will be welded over with a cut repair panel.
The pics aren't terribly clear. Imagine you've completely taken the wheel off and are looking directly upwards.
![](https://vwgolfmk1.org.uk/uploads/pbextract/654853/Dsc02339reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/654853/Dsc02351reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/654853/Dsc02352reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/654853/Dsc02360reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/654853/Dsc02366reduced.jpg)
Tomorrow (weather permitting) I'll be welding (upside down) the repair panel into place.
