Larger Servo Brake Light????
(In Topic #78515)
![SteveyJ in the usergroup ‘Regular’ SteveyJ in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Fit a switch?, T into pipe?
Didn't really want to go down the route of cutting into the pipe.
teammonkey
teammonkey
I used 2 tee pieces one for each brake switch . You will need two small pipes to connect from the master to the tee's but thats easy to obtain and cheap .
Saves a lot of hassle trying to re route wires and mount a pedal switch , easiest option tee piece ….
Chudd………….
Spent ages hiding looms etc don't want to spoil it all now with this last bit of wiring
teammonkey
Just need to know what part to get from these scirocco's and I'll be off down the scrappys!
teammonkey
