mk1 golf small 1300cc engine to polo 1.3gt on bike carbs :D
By converting to late Mk2 breakerless ignition you effectively remove the Rev limiter.
The cream de la cream would be to go to megajolt/magespark ignition - it's cost about ?150 to do but it means you can map 3D advance cures from your laptop in real time - how cool?
Megajolt is what I am aiming for if I ever find a valver to put my carbs on…
justs got a few little more bits to tinker about with, will get some more photos and vids up soon…….
simon
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Login to a private Photobucket.com albumOr is it best to find the r6's?
Steve_Matthews said
I *might* have a valver engine available in a short while. If anything comes of it, I'll let you know.
Cheers Steve, though you are a fair distance from me!!!
Turns out that my mate who had an engine lined up for me but had given up on it (couldn't get compression) thinks it ,ay still be OK. He suggests that I whip the head off and pop the pistons out as he thinks it may just be that the rings have rusted tight into their grooves as the engine has stood for some time with the induction set-up disconnected.
Fingers crossed - I may be back in business sooner than I thought!
u WILL notice a diffrence, its alot quicker then the mk1 1300, but have not had a proper chance to test it out at the min as a bit of debris of the road bounced up got wedged inbetwen my driveshaft and put a big hole in my gearbox but once i do get chance i will be uting some pics up and im hopeing to go to the track day coming up soon so will get some videos done.
good luck, p.s. if you want a polo gt engine and box and loom go on
www.clubpolo.co.uk sales section - few in there,
Login to a private Photobucket.com albumI have a question…
Below is a picture of the carbs I have with some of the tubes labelled.
Anyone have similar tubes on their carbs - if so, what did you do with them! Tubes 1,2 and 3 connect to the side of each carb unit - there is a fourth though the tube is missing.
Tube number 4 is a big bugger which connects the two banks together with a plastic "t" piece.
Did you plug them, or connect to a catch tank or something?
Local bike mechanic thinks my carbs are off an imported bike and that these would connect to the airbox - something to do with emmisions control?!? :dontknow:
:mrgreen:
and the other pipes left over are breather pipes,
and you might have a throttlew position snesor on there depends if the bike it came of had an ecu, if it has got one, dont worry leave it disconnectd
any other help needed let me know ill try my best to help
Login to a private Photobucket.com albumAll of the other tubes are breathers of sorts. I registered on "Fireblades.org" and got some good guys check out my pictures and point me in the right direction…
Happy now!
Just got to find some ally tube now to make my manifold. Local company today quoted me ?45 + VAT for a 1 metre length in the right dimensions! Barstewards - I'm not paying that!
keep us infored on how ur getying on, hopefully im goin scrappy this week sometime to get a box for mine, if i can find out what one to get and she should be all up and running again, ready for some sideways action round some roundabouts :y:
simon
Login to a private Photobucket.com albumwhat airfilter have people used for this in the past as i am refusing to pay 100 odd quid for a itg one where u have to cut the base plate to fit.
anybody got a sock filter or something close?
simon
Login to a private Photobucket.com albumTrying to find some tubing the right size to make up the runners… Not much luck at the moment though. The size I need is not an off the shelf size so getting quotes in the region of ?60 for a meters length!
ITG's often go on ebay for ?30 to ?40. I've got a set of old K&N style filters for Twin Webbers that I can mod to fit temporarily, though I would prefer an ITG foam type.
Most people use 4 mini K&N's specifically for the bike carbs. These are always on EBAY too, though they come in many different sizes!
cool will check ebay and that out
simon
Login to a private Photobucket.com albumsim0n_parker said
i have my manifold and then it attaches to the carbs via silicone hoses.
Silicon hose is not actually resistant to fuel, though I can't see that causing any major problems till the pipes are a good few years old!
Login to a private Photobucket.com albumAll My Build Photos - https://www.flickr.com/photos/pix-al/albums/72157622794406840
been surfing the web for someone to reprofile my cam, not for a pull ur trousers down and get ready for a bumming price.
u know of anyone fairly descent and not over expensive?
