Copper brake and fuel lines.
(In Topic #77851)
![vw_singh in the usergroup ‘Regular’ vw_singh in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Gurds
What about the fuel lines?
![Maniac in the usergroup ‘Old timer’ Maniac in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I brought a pre-made kit for about ?50 in the end, and they all fitted ok. Much less hassle.
Of the top of my head I'm afraid i can't remember the diameters of pipe needed, sorry!
Mike.
1983 White cabriolet GTi
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi4.photobucket.com%2Falbums%2Fy138%2Fmickowalls%2Fmichaelsglof003.jpg%5B%2FIMG%5D)
![micko in the usergroup ‘Local’ micko in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I've just finished doing this on my MK 1.
I used 3/16 (4.75) brake pipe - looks slightly thiner than the original stuff, but seems OK. Ask for Kunnifer (sp) as apparently it doesn't corrode / go green like the copper stuff.
I got a flaring kit from these people,
http://www.carparts-direct.co.uk/so_brakepipeflaringkit.cfm
The kit included pipe and fittings. The end fittings were a wee bit longer than the originals so I got some different ones from the local motor factors for ?6.00.
The flaring kit worked fine when I got the hang of it. I didn't have a pipe bender so bent the lines around a socket held in a vice.
![Avatar]([IMG]http://img.photobucket.com/albums/v296/dubbedup/737e7c2b.jpg[/IMG])
![dubbedup in the usergroup ‘Regular’ dubbedup in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Maniac said
You'll also need a flaring tool to do the ends of the brake lines with, but be warned do not buy a cheap one, as I made this mistake, and gave up in the end because I couldn't get the flares right.
Mike.
Anyone any idea where you would get pre made pipe kits….
For new sets of brake lines , ready made .
crazyquiff on here for fuel lines see …..
http://www.golfmk1.co.uk/
Cheers……..
Mike.
What are people's thoughts on DOT5 fluid?
