engine knocking help !
![berty in the usergroup ‘Regular’ berty in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
took it up prescote hill climb last year. planning a 95 bhp engine this year, i has allready got a brand new stage 3 jamspeed head just need a block to cope with it now.
only trouble is the wife has me building a new kitchen and the problem with the golf is setting me back a bit
to mr gti want a TVR :dance:
1983 lhasa green mk1 1.8 gti
old skool baby
old skool baby
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fmyweb.tiscali.co.uk%2Fmgmidget%2FPics%2Fcolour16.jpg)
![Robb in the usergroup ‘Old timer’ Robb in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I drove mine as a daily driver for a year before the accident!
Rob
http://myweb.tiscali.co.uk/mgmidget
Golf GTI Cabriolet 1990 Helios Blue - gone
Audi A4 1.9TDI - Gone![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
Golf GTTDI MK5 140…..oooh quick….but not a MK1
old skool baby
old skool baby
ps. going to use 20/50 oil to run in for 500 then semi 15/40 after
then i might caine it after about 1000000 miles :mrgreen:
old skool baby
old skool baby
![Mr_GTI in the usergroup ‘Old timer’ Mr_GTI in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
err no not really, i love the sound of them and have driven quite a few but I cant afford to run one at the moment and would rather have something more practical yet fast at the same time hence why I had the Impreza.berty said
The grit you found in your engine could well be particals from not running a filter but they tend to muck up the carb not get into the oil but if they got passed the valves then maybe. Its more likely to be really fine bits of your engine ground down into what now looks like grit. I would use a decent mineral oil to start with once you've re-built it and stick to a decent brand, then goto a semi once fully run in
berty said
looked the part , i would show you a picture of mine if i new how :dontknow: i would possabley be intrested in some bits and the block but cornwall, a long way to go from brum.
give us a PM if you want anything, can post :wink:
right where was i , the golf was knocking so i changed the mains the big ends and the thrush end float things. i put it all back together with love and nice running in oil and yes it still knocks no change what so ever.so its not the bottem end,some say its it could be the little ends,some say it could be a loose cam belt or cam belt pully,crank pully or even the. flywheel
every body i know has listened to this knock and 90% have said its nothing dont worry, so sod it i am not going to, i am just enjoying the car now yes i will run it in for another 1000 miles
i will keep my ears open on the knock and if it gets any worse ill be back.
ps thanks for everybodies help
old skool baby
old skool baby
