Seat belt mounting point
(In Topic #76908)
![](https://vwgolfmk1.org.uk/uploads/pbextract/638294/Dsc02036withhighlightreduced.jpg)
I found this on the internet, but I don't know if a Triumph TR6 has metric (M10) or imperial fittings!
http://www.rimmerbros.…ge=triumph/tr6/trim-belts
![m6m62 in the usergroup ‘Old timer’ m6m62 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Good luck with it,
Mark
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fmyweb.tiscali.co.uk%2Fmgmidget%2FPics%2Fcolour16.jpg)
![Robb in the usergroup ‘Old timer’ Robb in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Audi A4 1.9TDI - Gone![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
You will find worse rot when you take off all that trim especially under the stuck black trim by the back seat . Remember to remove the petrol pipes and breather behind the panel befroe you start ! Crazyquiff might have a better panel from a scrapper ? Worth a PM ?
Good luck with it Paul……..
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Rust looks exactly like mine did before I started cutting out. I'm sure you know already, but as chudd says get all that trim off you're bound to find the rot goes a bit further - I did.
I'm making my own plate up as we spek. I have welded two plates (80mmx80mm) of metal together which I will then drill a hole through to allow the seatbelt mount bolt through and into the nut I will weld onto the plate.
Chudd- did you take any pics of your one? How did you attach it. I intend to drill some holes round the edges of the plate and spot weld it into place.
1983 1100 C
1983 1100 C
Exactly what i did , take measurements chop out old metal , weld nut on to 4mm plate to fit behind new repair . Repair old rust bit then drill 6 large holes in it and mount the 4mm repair behind and button weld it to your new panel . You now have a new seat belt mounting plate behind the newly repaired old one , hope that makes sence ? Remember to drill a hole for the top of the seat belt reel locating pin ! Harder to explain than actually do . Worst bit i found was the rust in that round bit located under the rear seat trim , but it all looks good now its primed sealed and painted
Cheers and good luck with it Guys …….
