DIY respray
(In Topic #76748)
![Mitch in the usergroup ‘Regular’ Mitch in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
DIY respray
Im considering spraying my car myself…sounds a bad idea but my dads had some experience of spraying but not a whole lot.
I just need some decent info where to start..i have the compressor and gun (friends grandad) so if anyone has any info where to start etc prepping anything.
I think spray shops are seeing pound signs when the see a young lad, so ive taken the approach of ''why not give it a go'' the worst that can happen is it looks rubbish and i end up rubbing it down.
Any help at all would be great
thanks before hand Mitch
![Avatar](https://img236.imageshack.us/img236/6103/crestri7.jpg)
![daveyyoung in the usergroup ‘Regular’ daveyyoung in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
I really want to know how you get on as i have some touch up jobs and I don't like to think what some cowboy will try to charge! :cry:
Good Luck Buddy! :mrgreen:
http://www.carsprays.com/
The main reason why people often let others do a respray (even if doing everything else, eg welding and prep, themselves) is that the best paint to use is 2 pack, which has severe safety issues. Another reason is that you'd need to control dust effectively. And the other one, is that a proper bodyshop will have access to a low bake oven.
But, you could do it yourself and get a good finish, with care!
![Avatar](https://i2.photobucket.com/albums/y12/PhillT1/Animation4.gif)
![PhillTMK1GTI in the usergroup ‘Local hero’ PhillTMK1GTI in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
get yourself the Haynes Techbook - Body Repair & Painting manual.. well worth it (available from amazon)
ref prepping, take your time to get it perfectly flat with around 800grit sand paper
get a good 3-4 coats of primer on it.. then spray some pretty patterns with a black spray can all over, then sand this back until all the black has gone
once you've done that, clean the car with thinners then apply thin top coats, leaving for around 15-20 minutes each coat
I put about 5 coats on.. then leave it a day or two, and with some cutting compound (G3 for example) or VERY fine sandpaper (2000 grit) and soapy water start rubbing back for that nice smooth finish
probably loads I've missed as it's a quick post :wink:
I agree with youngdavey…i realise theres a fair old bit of work involved but as far as materials are concerned its not too expensive…?2400 is a bit of a micky take.
I think im going to invest in a manual and give it a try
so am i right to break it down into these steps
800 grit down to the metal
3 coats of primer
spray pretty black patterns
rub down so black paint dissapears
apply top coat
rub down with 2000 grit
laqcuer
where would the filling step fit in?
many thanks again guys
mitch
For safety with 2 packs, try this link:
http://www.hse.gov.uk/pubns/indg388.pdf
Basically, you need to be able to put the car into an airtight and filtered 'booth' and wear an air-fed mask and all-enclosing, disposable, overalls.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Ref the 'spray black patters' - Phil is right, it's called a guide coat. Doesn't have to be black - I've seen red used often. It's a very thin coat of paint, to show up any imperfections before you top coat as the primer can make the finish look a lot better than it really is being matt, will hide tiny scratches etc.
Good luck with it and keep us posted how you get on
![robdcfc1 in the usergroup ‘Local’ robdcfc1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Sand all flaky paint etc off with 2-400 grit wet and dry
Do any filler work that is needed (take your time reshaping youll be happier in the long run)
1 -2 coats of etch primer to kill that nasty tinworm dead!
Apply a coat of high build primer to the whole car, once this is dry you need to flat this back with 800 w/d using either spray paint (a fine mist) or you can buy guide coat to show up the low spots. Flat back just enough to lose all the guide coat (if you flat through the primer apply some more and do this step again!)
Once shes flatted down and your happy with it you can apply a basecoat in your chosen colour (if its a dark colour you may benefit from using a coat of black primer first)
If the finish is a bit like orange peel you can flat it back again Make sure you wet sand it take your time and wipe it dry you will be able to see any texture thats left!
Apply 2nd colour coat then you are ready to clear coat apply this medium wet allowing plenty of time between coats for it to go tacky (stops runs and colour drag)
Apply as many coats of clear as you want
Leave in the garage more 3-4 days with some form of heat in there not too hot just to help it cure and moisture etc
Go back andwet sand the clearcoat carefully until the "orange peel "effect has gone. (keep wiping it dry you will see the texture when its dry)Making sure you keep the panel wet while sanding using plenty of CLEAN water.
When you have a nice smooth but dull finish its time to polish
If you can get use of a polisher it would be a good idea (takes forever by hand)
Use plenty of Farecla G3 or similar from your motor factors they wil advise you what to use from what they stock.
Keep polishing until you have a really nice finish (be careful on edges and contours the mop can cut through if not careful)
Apply a coat of glaze or polish and shes done
Hope this is useful it took me bloody ages to type :mrgreen: :mrgreen:
Rob
any ideas of how i can breath clean air then? i like my mk1 but i wouldnt fancy dieing for it lol
ill get some pictures up im going to get the first grade paper and rub it down maybe tuesday!
You need a positive pressure, sealed, air-fed respirator. For example:
http://www.supremevisors.com/air-fed-visors.htm
To supply this, you'd need a compressor, sited outside the spray booth area, with enough capacity to supply both the respirator and the spray equipment at the same time.
You will still need a face mask though as the fumes will "catch" the back of your throat and make you feel a bit ill.
Another tip to stop you from getting loads of dust and crap in your paint is to damp the garage floor down with water
Rob
![cedar in the usergroup ‘Old timer’ cedar in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
just been flicking through the HSS hire book and ive managed to get a mini turbine compressor and gun for ?35 + ?18 per day there after….
so…few more questions
does the cellulose based paint work in the same way as the 2 pack?
Am i right in thinking i should use an angle grinder with relevant discs to sand the body?
And the one biggy i have is….the windows and seals, what should i do about them without giving myself too much of a hard time?
cheers Mitch
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
cheers Mitch
No biggy…
Been covered here a couple of times. Use the search and look for windscreen seal or removal or something. All windows are easy to take out and easy to put back! I even managed all of mine on my own.
My Build Thread
For sanding down, I'd use a wide variety of wire brushes as fitted to a power drill, for getting into the nooks, etc of the body. And there will be some areas which you still cannot reach, so you'll need to do some by hand, getting your fingers in. If your fingers are too thick for edges, you can wrap sandpaper around pens, pencils, the tip of screwdriver, etc etc.
Are you sanding all the paint off for a bare metal respray, or are you just 'keying' it to allow new paint to go over the top of the existing stuff?
the hardest one I found was the rear hatch, VERY snug fit!
