Rust Bullet, Any tried it?
(In Topic #76311)
![vw_singh in the usergroup ‘Regular’ vw_singh in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
http://rustbullet.com/HowItWorks.htm
Anybody tried it? Its supposed to be the best stuff designed for use on military aircraft etc.
Guest user
Do you rearly need to spend that much money when other products will do the same job :dontknow:
Personally i would only use what has been recommended by others or use products you trust yourself .
So i have to say no i havn't used it and would recommend Finnegans NO1 Brown primer or Davids zinc rich primer on hard to reach places . Top coating with a suitable paint or underseal / Wax .
Cheers…………
best i would go for is Bilt Hamber - deox C gel - brush it on the rusty patch leave for 24hrs and wash off - no rust at all left - then epoxy mastic on it. its the best honest!
The way we do all the "proper" restorations is to take the car back to a bare metal shell, chop out and weld up all the rust then (and only then) send it to the blasters to be sandblasted. Then when what's left comes back, weld up all the new holes that have appeared and lead load them ready for paint.
If this brush on stuff really worked, no one would ever weld anything up would they? I'd rather hit the tree/lamp post/other car knowing that at least the shell was sound rather than worrying about where the covered up rot is!!
i had no holes or rust on my floor pan but i used the best treatments i could find to ensure further long life of the metal..
if the steel is pitted heavily or right through then you cant avoid welding in new steel.
Gurds
