Group buy on twin carb manifolds for small blocks ?
![Avatar](https://i34.photobucket.com/albums/d128/alfa_delta/Steve_GTI_tn.jpg)
![Steve_Matthews in the usergroup ‘Old timer’ Steve_Matthews in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If people asked very nicely I could be pursuaded to knock up a limited run of them myself…
![Dub_Driver in the usergroup ‘Local’ Dub_Driver in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
hmmm
![](https://img.photobucket.com/albums/v105/jimmymoo/mangosiggy2.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/mk1-golf-blue.jpg)
![erndub in the usergroup ‘Regular’ erndub in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
I'll see if there are any other websites where people might want them - more I do, cheaper they should become.
I'm guessing postage won't be cheap but I'm in the North of Engalnd and regularly in the midlands too…
![Avatar](https://i51.photobucket.com/albums/f354/Ratbus100/5901626504640918668854.jpg)
![Gold-mk1 in the usergroup ‘Old timer’ Gold-mk1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
thanks.
Mines an HKcode mk2 engine, are they the same amount of studs ?
Real golfers don't play with clubs
Steve_Matthews said
They will fit 895cc, 1049cc, 1272cc and even the Mk3 Golf 1.4 engines - all the same stud pattern. There is a slight difference in head deisgn between the water heated and exhaust heated inlet manifold cars but don't worry about it - I'll give you all the info you need on that.
Excellent, for the record, i've got the water cooled manifold.
If yours is exhaust heated - it isn't the end of the world - my first motor was and there are ways round it without having to resort to swapping heads.
![Avatar](https://i2.photobucket.com/albums/y23/redpetemk1/avtar.jpg)
![redpetemk1 in the usergroup ‘Old timer’ redpetemk1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Small blocks rule, i rebulit my carb recently, and rebuilt the head, after it went (winter last year), and last night set up the idle and the mixture (runnin a bit rich) :roll: , took it for a test drive so much better, much quicker, wind up the revs, and it really goes, really impressed with it
Ill have to think about this, though it's sounding good :wink:
![mk1_driver in the usergroup ‘Regular’ mk1_driver in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/632087/bikethrottlebodies.jpg)
Engine flange and 4 seperate runners? (for me, no DCOE flanges)
Does anyone know if I can use the injectors in my GSXR throttle bodies for something like megasquirt?
![Avatar](https://i11.photobucket.com/albums/a156/danH73/Vwgolkfmk1.jpg)
![dan_73 in the usergroup ‘Paid Member’ dan_73 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![dan_73 in the usergroup ‘Local’ dan_73 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Steve, do you mean making something like this:
same for me, got carbs.
yes you can use the gsxr injectors, make sure you have the mini loom to make wiring easier.
if you can get hold of a copy of practical performance car mag sept 05 their is a nice little piece on bike t/b's on car engines.
i'm working on finding a local supply of manifolds at the moment, i'll keep you all informed.
Rusty Hookers Dub Club
Any updates everyone ?
Steve ? any news on making some of these ?! cheers matey.
I'll keep you lot informed.
Steve_Matthews said
Well I'm about to pull an inlet manifold off to make up all the patterns up![]()
Top man ! Look forward to seeing/hearing/reading the results !
