driveshaft seals
(In Topic #75360)
![andunp in the usergroup ‘Local’ andunp in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
driveshaft seals
and wots the best way to get em out??? :dontknow:
![toad in the usergroup ‘Regular’ toad in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Unbolt the driveshaft from the flange
Remove the plastic cover from the end of the flange, this reveals a circlip.
Remove the circlip and then remove the flange from the box.
Tap in the new seal and then put everything back together
The seals can be bought separately from VAG as a kit, it contains the seal, circlip and plastic cover , they cost about ?20.
You'd probably be best off getting new bolts for the driveshaft, these also come in kit and are about a ?10 I think.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
This spring then makes for an entertaining afternoon trying to get the flange back on?.. (long bolt with length of bar to pull flange on but then leaves little room for fitting circlip)
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
I had loads of fun on with the ?box out of car on the bench, wouldn?t fancy it crawling around on the floor in a confined space, good luck.
:? :evil:
