Mystery Sensor on 1990 Cabby
(In Topic #75085)
Golf GTI Cabriolet 1990 Helios Blue - gone
Audi A4 1.9TDI - Gone
Golf GTTDI MK5 140…..oooh quick….but not a MK1
Just another point, it might of been added to the car in the past from a previous owner and has nothing to do with that engine. Also the engine code/tranny code would help in the search of your car, listed are loads of engines. Type of injection it uses as well. eg.. digipants..
any how, we will come up with an answer.
Not seen anything like that on a mk2 either not k-jet or digifant?????
Is it something of a system like k-star or similar????
Can you buy ETKA from anywhere so I can search? thank for all your help in this quest for knowledge
Rob
191 919 521 B - thermal switch cylinder head for models with radiator fan run-on for models with towing facility. It says its blue and the switch opens at 110 oC
Does you car have any sign of a towbar??!!
I do belive i have found it!.. it looked to me as a temp sensor of sorts, SO here is the ETKA part number 191 919 521B
And here is the etka screen grab.
http://uk.geocities.com/satelliteone/sensor_thermal.jpg
What do you rekon Robb?
Rob
I could do with the same sort of idea for my carb. When the manifold heats up the petrol remaining in the carb, it a bugger to start. after 2-3 mins. Bad design! Perhaps a home made plate might suffice..mmmm itchy chin monent comming on!
any how robb i dont think you need to worry and i have`nt got a clue what the colour is for the wire. You could alway try to trace it to see if it has anything to do with the cooling fan circuit.
The brown and white wire is supposed to be there, its the earth for the dash! Lots of odd problems occur to your instruments when the wire is disconnected. Its often forgotten and not reattached after the rocker covers been removed.Well done both, must be unused then, whats the brown/wht wire for? its connected to the rocker cover with the earth strap.
I'm not sure what your full beam LED prob could be, could well be something to do with the dash itself like satelliteone suggests, or a prob with the stalk switch. Try and make some sense of the wiring diagrams in the haynes and follow the wires… that'll keep you busy!
satelliteone -
What a snap hey!well bugger me beaten to it!!!!
Ross
I had a MG midget before this and the wiring diagram for the whole car covered one page
Mike.
1983 White cabriolet GTi
