Rocker Cover Screw peg things
(In Topic #74657)
![smithysmoo in the usergroup ‘Local’ smithysmoo in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Any way the two that hold down the cover for the timing belt just started spinning. Have had to cut the nuts of and now the pegs are mullered, and I've removed them with mole grips.
Do VW still do these screw in pegs (they better) and also how do you screw them in tight so as you don't mess up the thread where the nut goes.???????
Going to change my gasket now while I'm at it and hope this helps the leak. But for now car is off the road. :cry:
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
Any help aprreciated. Would the car leak oil from the rocker when at standstill as the oil level in there is well below the rocker line.
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
To screw the pegs in tight, you could put two nuts on one end, and tighten these nuts against eachother. Then use the top nut to screw the peg in.
Not sure about the oil leak though… No oil should leak from it while the engine is stopped…
Yeah didn't think it should be leaking when the engine was stopped but its deffo coming from that area, and it only does it when the engine is still hot so I'm hoping that this will solve it.
:dontknow:
![Ross in the usergroup ‘Old timer’ Ross in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
The new gasket was a rubber one and the old one was the cork one with the separate pieces at the ends.
I removed all the old studs with a monkey wrench, was a bit daunting doing it as once the wrench stripped the threads there was no going back!
Be careful if you do use the 2 nut on the peg trick not to damage the threads on the new studs, it is easily done, i wouldn't really recommend it but dont know of a better way to do it!
Cheers,
Ross
![](https://i2.photobucket.com/albums/y29/rossonline/sig1.jpg)
![russt in the usergroup ‘Old timer’ russt in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Campaign Mk 1 Black
16v Mk2 Red (decsd )
They have become quite rusty now though and when I unscrewed 2 nuts to get the cam cover off the studs came out with the nuts so obviously they're not night enough. Next time I have the cover off again i'll do the same and replace the studs and use a bit of anti-seize copper grease to stop them rusting up.
I cant remember the price but it wasn't much at all, give you local VW branch a call.
Cheers,
Ross
Anyway have phoned them and ordered a gasket for my engine code (DX) and have also ordered the pegs separately as they said nothing about new pegs coming with the gasket.
Gasket was ?9 ish + Vat does this all sound right, and then ordered 3 pegs which I need and 1 spare in case anything goes wrong.
:dontknow: :dontknow:
Hoping to have this Friday so I can get it working for weekend.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/92image.jpg)
![Cero in the usergroup ‘Old timer’ Cero in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
