Handbrake:banghead:
(In Topic #74572)
Handbrake:banghead:
He denied even touching the handbrake even though it was on! And offered to pay for it even though he swore he didn?t break anything!!! Anyway I got the money and decided to fix it myself.
Used my Haynes manual to take apart the drum and replace the cable. All in and hooked up. There is resistance there now. Thing is the ratchet mechanism is not holding the lever up!! Does this mean the lever is broken aswell or maybe I am missing something? Help!!!
Jjl.
2003 MKIV Golf PD150 GT TDI
But I did manage to squash the actual handbrake at one point which has the ratchet inside and that meant the thing wouldn't go down properly.
Your ratchet thing could be stuck inside, theres a little swingy peg thing that is released when you press in the button, sounds like it's depressed all the time, probably just needs a good fiddle.
My problem was because I live on such a slopey hill I have to have the car in gear to release the handbrake! Not ideal. Think I'll wait till I move and have my new flat driveway to get properly stuck in!!
Peter.
1980 1600 GTI, daily driver.
Anyways, it could be that you have the cables adjusted up too far so that the lever doesn't latch onto the ratchet quadrant at all since the brake is already fully on. Try backing off the adjustment..you should hear approx 3 clicks of the ratchet as the brake starts to come on.
PS: always do your reverse flicks right-hand down (RHD Golfs)
Mk1 GTI
B5 Passat Estate 5 SPeed
Riley 1071"S" Elf Mk2 (Bl**dy Hooligan machine!)
Bosch Lawnraker 32
Bosch Lawnraker 32
