Floor pan getting VERY hot from Exhaust
(In Topic #74575)
![Avatar](https://i2.photobucket.com/albums/y12/PhillT1/Animation4.gif)
![PhillTMK1GTI in the usergroup ‘Local hero’ PhillTMK1GTI in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://img.photobucket.com/albums/v502/dubboy/76%20GTI/Driveravatar2.jpg)
Life Member
![dubboy in the usergroup ‘Local hero’ dubboy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![dubboy in the usergroup ‘Moderators’ dubboy in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![dubboy in the usergroup ‘Paid Member’ dubboy in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![tallpete in the usergroup ‘Old timer’ tallpete in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Check your heat shields still intact!
LOL, maybe you need to do a spacewalk and check the foam tiles.
Buzz.
1980 1600 GTI, daily driver.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I'm pretty positive I don't have one. Would a "driver" have had one fitted as standard or was it just the Gti's?
My Build Thread
there's a heat shield by the fuel tank, rubber gear linkage boot, gear linkage support bracket/mount thingy and the obvious at the front.. just seems the rest of the area is a bit exposed :dontknow:
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![tomo320 in the usergroup ‘Old timer’ tomo320 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
good luck chap,
paul
![andunp in the usergroup ‘Local’ andunp in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
costs a bomb in houses!!!!! so you should think yourself lucky.
andunp said
just timk of it as under floor heatin!!!!!!
think the exhaust mounts are knackered as it's sitting a little to one side
![Avatar](https://i8.photobucket.com/albums/a43/lowmk1/sfdh-1-1.jpg)
![lowmk1 in the usergroup ‘Local’ lowmk1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
1272 driver with a magic tree!!
lowmk1 said
ps. sorry for thread hijack :mrgreen:
if the exhaust is rattling against the heatshield I suspect it's not in the right position (exhaust and/or heatshield).. have you tried bending the shield away?
yep exhaust it tight as, doesnt move about alot and is std(i think) where it meats the heat sheild.
Can i just rip it off and cover the rubber with some sort of heatcover thingamajig
Life Member
