Floor pan getting VERY hot from Exhaust
(In Topic #74575)
Life Member
Check your heat shields still intact!
LOL, maybe you need to do a spacewalk and check the foam tiles.
Buzz.
1980 1600 GTI, daily driver.
I'm pretty positive I don't have one. Would a "driver" have had one fitted as standard or was it just the Gti's?
My Build Thread
there's a heat shield by the fuel tank, rubber gear linkage boot, gear linkage support bracket/mount thingy and the obvious at the front.. just seems the rest of the area is a bit exposed :dontknow:
good luck chap,
paul
costs a bomb in houses!!!!! so you should think yourself lucky.
andunp said
just timk of it as under floor heatin!!!!!!
it'll be good in those winter months that are coming up!
think the exhaust mounts are knackered as it's sitting a little to one side
1272 driver with a magic tree!!
lowmk1 said
ps. sorry for thread hijack :mrgreen:
No worries!
if the exhaust is rattling against the heatshield I suspect it's not in the right position (exhaust and/or heatshield).. have you tried bending the shield away?
yep exhaust it tight as, doesnt move about alot and is std(i think) where it meats the heat sheild.
Can i just rip it off and cover the rubber with some sort of heatcover thingamajig
Life Member
