Help...... arch rolling tool needed!
(In Topic #74369)
![Avatar](https://i3.photobucket.com/albums/y62/kins888/l_11169df0ad11820901b08b35d181a2fb.gif)
![kins in the usergroup ‘Old timer’ kins in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
When there is just me in the ride is great and does not scrub . I had 4 other people in her last night ouch
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
Right for me to keep my friends I need to roll some steel!
I've done some shopping around and found that Frost sell an arch-rolling tool for ?225. As I only need to do this once I was wondering if it is possible to rent these. I don't want to resort to shaping the arches with a hammer and a piece of wood 8O and would like to avoid dropping it in at a body shop. It's much cheaper doing it your sen and more fun!
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
Any ideas….. has anybody got one I could borrow???
Thanks Karl
![zak in the usergroup ‘Regular’ zak in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![](https://i3.photobucket.com/albums/y94/sakander/signature.jpg)
Helios Blue
![Avatar](https://i8.photobucket.com/albums/a43/lowmk1/sfdh-1-1.jpg)
![lowmk1 in the usergroup ‘Local’ lowmk1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1272 driver with a magic tree!!
![AUSGOLF in the usergroup ‘Regular’ AUSGOLF in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Mine is lowered 30mm and I have not had any trouble (that I am aware of)
Paul
Helios Blue
I've set it up so there is 50mm of thread left on all corners. Not sure how you work out how low it is from standard. Any ideas?
How low??….I can just about fit my fingers in between the wheel and the arch at the rear. It makes swooshing noises as the air passes through the gap when you bounce her I think she looks spot on at this height and is just about ok as an every day driver if she did not scrub at the rear when laden. I've tried gently persuading the arches out but with no reward. I think the rolling tool is the best way forward.
Zak you can see pics of my car in my new car thread in this section
![alexh in the usergroup ‘Regular’ alexh in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![tomo320 in the usergroup ‘Old timer’ tomo320 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![walt in the usergroup ‘Local hero’ walt in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Low mk1
![:nerd:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/nerd.png)
tomo320 said
you can make your own arch rolling tool, never tried it myself, its in one of the old golf mags, uses vw jack and clamps to wheel, i aint got a scanner tho but can post it you
Thanks tommo320, but lowmk1 has lent me a home made arch roller. It's as you describe made out of a jack…. looks like it should do the trick. Big up lowmk1 and the rest of the NWM! 8)
