Mk1 resto - list of items completed now added
![o in the usergroup ‘Paid Member’ o in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![o in the usergroup ‘Local’ o in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
After a lay-up of 2 months my Mk1 restoration project has started up again. I'm just back from my 4th day at the workshop and things are progressing nicely, if somewhat over-budget
First things first. Stripped the head off the engine and sent it off to Dave the head man - this bloke is a total pro, even though it ain't cheap! The head is now back with new valves, springs and guides as well as a host of other changes. It looks great and I can't wait to attach it to the bottom end. Speaking of which, while the head is off i'm painting the block (see below)
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Painting.jpg)
The bottom end has been stripped and is getting new Mahle (spelling?) pistons, rings, end caps and anything else it needs. The crankshaft is like new so didn't need anything doing and the bores are also excellent, very impressive considering the miles its done. The engine bay was given a healthy dose of Autoglym degreaser and then pressure-washed to get rid of 22 years worth of grime and the whole bay is now shining
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Jetwash.jpg)
I have been stripping and detailing as the project has gone on. The sump and rocker cover have been sandblasted and are awaiting a coat of satin black or two (below)
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Shotblast.jpg)
The clutch on the car was knacked so a new LUK one was fitted. While the gearboc was off I spent ages cleaning it and then painted it so it now looks like new (Below)
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Painted.jpg)
Now all teh parts are ready for the bores to be honed and engine to be rebulit using the lovely new parts and painted ancillaries. I can't wait till that happens, should be done by next week hopefully..
Now the engine is on track work has started on the body. As xcan be seen arlier I had already started stripping the car so now all that needed doing was the prep work. I'll be honest, there was more than I first though. The rear panel needed a lot of work (see below) but now looks great and is all ready to paint.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Image006.jpg)
I also sourced a 'good' used door but it turned out to be pretty rusty and therefore needed a lot of prep work also
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Mk1door.jpg)
When I left today the sides were being filled and sanded down in preparation for the primer that is due to go on tomorrow at some point (I won't be there for that as i'm in an exam!)
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Sidemk1.jpg)
I spent most of friday fitting the only modified area of the car (I want the project to be as original as possible) the Mk2 16v brake servo. It was a bit of a 'mare to fit and I need to get a couple of new pipes made up but i'm sure the improved feel will make it well worth it.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Mk2servo.jpg)
Another very pleasureable job was that of restoring and fitting up the front grill components. I first primed the trims in zinc primer (necessary for aluminium) twice and then left them to dry.
![](https://img.photobucket.com/albums/v705/oalloyd/Trims.jpg)
Once that was done I sprayed them VW Mars Red and fitted them to the correct grill that I got off e*** which included the original Hella fog lamps. I think the final result looks awesom and will look even better once the VW and GTI badges have been added.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611391/Grill.jpg)
I'll keep on taking pictures as I go and let you know how it gets on if your interested. Any comments/encouragement welcome; this project is taking a lot more effort than I first thought, even though its still really enjoyable.
o
Too many to list but 2 x 1982 Golf GTi 1.6 hatches are the main ones
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
Mrv - make sure you have a lot of space, time and money if your going to do a proper job on your car. My rear arches alone are a pain, let alone all the prep work for the respray!
o
P.s. I sold my 306 Rallye so am now back down to two cars again *phew*
![Avatar](https://i2.photobucket.com/albums/y12/PhillT1/Animation4.gif)
![PhillTMK1GTI in the usergroup ‘Local hero’ PhillTMK1GTI in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Keep the pics coming as it's nice to see other peoples projects and what they're up to with them… not enough resto posts if you ask me!
you sticking to the orginal colour? it's amazing what a new coat of paint can do!
The car is going to be campaign spec thoughout, hence the fog lamps etc. It pretty much was when i got it so I might as well finish it off properly.
o
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
o :wink:
![ChrisB in the usergroup ‘Old timer’ ChrisB in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
My Campaign has been a bit neglected over the past few weeks as I have been fettling the five ready for sale. Just need to touch up some small paint chips and a bit of tidying and hopefully I'll be there. Bit worried I won't sell it for as much as I hope though :cry: .
Still as you say hopefully I can pick up another over the winter when prices drop a bit.
Keep the resto pictures coming.
Chris
Its going to be get once it's done, the new pistons will mean there will be little if no rattle around the bottom end that happens to older cars when the piston to crank bearings wear
All the best with the MX5 sale, do emphasise the fact that its a UK car and not an import; the owners club guys are always banging on about there being no difference but try telling an insurance company that…
o
Plus UK fives over 10 years old are eligible for classic insurance that brings things down a lot. I can insure my five and the Campaign for less that I used to pay for my '99 MX-5.
Classics are definitely the way to go.
Chris
I want to get my mk1 on a classic policy when its done but i'm moving back home to london for a few months so could prove very expensive
Does your Golf want some company for a few months? It could have the mk2 as a younger brother if there's space in y9our garage
o
Can't you just declare the Mk2 SORN and hire a cheap lockup somewhere.
I think you will find the insurance on the Mk2 16v prohibitive in London though, unless you can get it on a classic policy. My Mk2 Jetta GTi 16v used to cost me over 500 quid fully comp with full NCB in London - nearly half the value of the car, thats why I got rid of it in the end :cry:
Chris
Yeah, renting a cheap garage would be ideal, but the question is where to find one? If you know anyone around who is renting one out cheaply let me know!
o
The wheel arch kit and front bumper are out of stcok nationally so I'll be waiting a while for those
o
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
A bit has been happening since I last posted pix, all very exciting! The hard bodywork prepping started mid last week and is coming along nicely. A few patches have been found, checked, reprepped and repaired. The front door has taken a lot of work but is now ready for its final coat
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Paintdoor.jpg)
The rear panel has now been primed and rubbed down so is also ready for its final coat of lovely Lhasa Green…..
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Rears.jpg)
There was one small dent in the front panel which how now been filled, skimmed and put into primer ready for the painting of the front end.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Dent.jpg)
The front panel had some bending at the bottom edge (common is GTi's with their low front spoiler) which I have pulled out, ground down and rust-proffed. What you see here is the stone-chip shield being applied by Andy the bodywork genius!
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Lfront.jpg)
The rear arch on this side was in a bit of a stage. After cutting away the outer sections that were rotten the inner sill was repaired with new metal. It turned out to be not too bad but any rust that was there is now banished!
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Arch.jpg)
The other rear arch wasn't as bad but still needed new sections welding in. As can be seen here, the effect is excellent and you can never tell that ity was touched.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Reararchdone.jpg)
The drivers side door was peppered with car-park rash so the whole thing was skilled, filled, skimmed again….
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/D.jpg)
The door now looks ace, here it is in its etch-primed state, it has now been rubbed down and is ready for the top-coat.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Fs.jpg)
Here the lower part of the rear panel has been sprayed with stonechip shield and is ready to be sprayed.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Primerear.jpg)
Here is a shot of the final taping up of the car. It is getting its top-coat tomorrow evening. It has taken ages to Scotch-brite the body to get the paint to key to it properly but the effort will be worth it.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Wrap.jpg)
Its not just been bodywork happening on the car this week. The pistons have now been assembled and inserted into the freshly-honed bores. It looks so clean now! The equally shininy new head is going to be attached tomorrow before the final topcoat goes on. The car is then going to be left to dry for a couple of days before the wet-flatting and buffing is done.
![](https://vwgolfmk1.org.uk/uploads/pbextract/611862/Bores.jpg)
I can't believe that this project is now nearing its final stages. All the complex engine and bodywork will be finished by wednesday night by Andy. I'm then going to go back to the car next week to start re-assembly of the trim and final detailing (so satisfying!). I'll take more pix tomorrow as the engine is put back together.
Its been hard work but she's now nearly there! I can't wait to start running her in!
All comments welcome, good or bad!
o
I hope she won't have for sale signs in the window by then, this project is working out rather expensive…..but hey, she's worth it!
o
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
the engine build-up carried on today. When I got there the head was already on so I spent most of teh day assembling the ancillaries. Here is the block with the head just fitted..
![](https://vwgolfmk1.org.uk/uploads/pbextract/611979/Headon.jpg)
And here is a picture with the freshly overhauled intake manifold fitted..
![](https://vwgolfmk1.org.uk/uploads/pbextract/611979/Intakeon.jpg)
When I left today at 6 the sump was painted and back on, as was teh alternator, starter motor, gear change mechanism, clutch cable, throttle body, rad and cowling, injectors and cambelt gubbins. Not bad for a days work!
The car is getting painted tomorrow evening and final fitting will commence a week today once its running.
o
