brake lines
(In Topic #73124)
![dazr32 in the usergroup ‘Local’ dazr32 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
brake lines
can anyone please help i need to replace some brke lines on my mk 1 but want to do the whole job myself from start to finish, only the pipes that need replacing cos some of them are quite tricky and look like an engine out to do properely. the pipe to the rear drivers side has already popped today when i was reversing the car out of the garage so that is immediate but i would like to do the rest. does anyone know where i can get an assembly kit or replacement pipes from. also while i am at it should i change the servo for a 16 valve one, if so any info on this mod would be appreciated thanks .
mk1 gti mars red /deep blue pearl r32
![Avatar](https://i619.photobucket.com/albums/tt275/gtiworm/GTIavatar.jpg)
![superworm in the usergroup ‘Local’ superworm in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Automec do the brake pipe kits as well as the metal fuel lines.
http://www.automec.co.uk
You can get a pipe flaring tool and a simple pipe bending tool relatively cheaply from Machine Mart or other such tool supplier.
Alternately check yer local Yeller Pages for Hydraulics Supplier…they will have the pipe and fittings in stock
Mk1 GTI
B5 Passat Estate 5 SPeed
Riley 1071"S" Elf Mk2 (Bl**dy Hooligan machine!)
Bosch Lawnraker 32
Bosch Lawnraker 32
nice one superworm thankssuperworm said
Yo Dazr
i will have a look at that site now and will get the kit ordered have you fitted them and are they relatively straight forward.
Used Automec for my fuel pipes but used their Brake pipe kit on my Riley Elf may moons ago. You need to specify the Copper Nickel (Cupro-nickel even!) since I don't trust plain copper for this application (vibration = Work-hardening = fractures = fluid on floor = no brakes = ouch)
The beauty of the Automec kits is that each pipe is the correct length and has the correct fittings/swages so all you need is a cheapo pipe bender (you can use thumbs but you will be in danger of flattening the pipe if the radii are pretty small)
You can use steel pipes but you will need to provide greater protection to them than original if you want them to last forever.
Note also that someone is flogging "chrome plated pipe to hose clips" on e-bay at the mo
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=23013&item=7964067900&rd=1&ssPageName=WDVW
although I believe they are still available from VW : Pt. No. 803 611 715
Mk1 GTI
Bosch Lawnraker 32
Bosch Lawnraker 32
brake lines
i have looked at the site and am going to order the copper nickel set for my car . i think i will put a bid on the goodridge brake pipes that were on ebay as well. thanks for your help, seems that the pipe replacement might not cost as much as i first feared. nice one. :wink:
Before you go bidding daft on those goodrich flex pipes, call or checkout German & Swedish for price….sets are hanging on the wall in the Trafford Park GSF shop…not sure if they're listed on the web tho:::::
Car Parts & Spares -- Buy Online with Fast UK Delivery | GSF Car Parts
(Had a look see Part No 99580 ?43 inc VAT.for all 4 lines..spend a bit more and get free postage !)
Mk1 GTI
Bosch Lawnraker 32
Bosch Lawnraker 32
