GSF reversing switch MFA sucess!!!!!!!!!!!!!!!!!!!!!!:lol:
(In Topic #72640)
Will try and describe how I did it more clearly at the weekend.
Does the gauge still work in fifth? I?d be keen to know how you did it as my reverse don?t work and I?ve tried rebuilding the switch twice and using parts from a second switch all with no success. Well done that man!
Don't bother rebuilding the old Reversing switch, buy the GSF switch and alter 2 wires in the block using a needle. Slide the needle in from the front of the block and pull the wire at the rear the wire and the female spade will come out of the block, before you push it in other slot spring up the spur sticking out from the rear, then when you push it in the female spade will click into place. I need to draw a diagram to explain and will do this when I have some spare time.
Viewed from above:
Spade 1 & 3 = left plunger switch = ecom meter
spade R & 15 = Right plunger switch= reversing light
I relocated the two inside wires from the lower outside(on the old switch) to 3 & R
![littlekev in the usergroup ‘Local’ littlekev in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1996 Gti Anniversary 8v Mystic Blue
1995 Gti 16v Fjord blue
Its the reversing switch available from GSF that can be converted, the switch is from a mk 2 GTI or MK3
My MFA is working properly now for the first time in 5 years along with the reversing light. Very happy.
Well done mate for working that one out. Will make a big difference to a lot of people now there is a readilly available part. Look forward to seeing your 'how to' article!! :wink:
![RT in the usergroup ‘Regular’ RT in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Leon
82 Lhasa Green Golf Mk1 GTI
It works perfectly for me, both the reversing light is working with the MFA.
The switch is brand new which means my rotten old switch has gone in straight in the bin!
The beauty is that if you do find an original VW switch you can switch back the wires on the block. Doubt if you will ever find a new Reversing switch from VW.
All happy in the Lhasa camp
:roll:
I think the GSF switch will work on all the MK1s with the block type switch .My spades on the old block where numbered 1-2 and RL2 the working pins at each side of the block. Will try and do some drawings at the weekend.
bblaaaaaaahh!!
I've got a cheap Nokia 6610 and hopefully I will get some piccys up loaded soon.
![psparrow in the usergroup ‘Regular’ psparrow in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
pics
I'll try and take some more tomorrow.
Feel like I've let the side down
![](https://vwgolfmk1.org.uk/uploads/pbextract/608990/PICT0048.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/608990/PICT0045.jpg)
