Exhaust gasket nightmare!
(In Topic #73100)
When trying to undo manifold/cylinder head nuts found two nuts at one end came loose easily with a 12mm socket. However, at the other 12mm is too big and 11mm wont fit on :dontknow: the nuts don't appear rounded off? Do I need a 11.5mm socket/spanner?
Thinking best approach may now be to remove inlet manifold to get better access at exhaust fixings. The bolts on the inlet manifold have a hex allen key type end. Can I buy sockets to undo these?
Any advice much appreciated
1983 1100 C
1983 1100 C
The first time I removed my exhaust manifold I took the inlet manifold off to get to the rusty nuts that didn?t seem rounded at the time but wouldn?t fit either 11 or 12 mm sockets, it made it much easier. I think i found a socket that fitted better in the end I cant remember exactly.
You can get hex socket bits to remove the inlet manifold bolts. Or you could use an allen key with an extension tube on the end for leverage if there's enough space.
Do you think there will be enough room to get the exhaust manifold and down pipe off while they are still together? Won't the anti roll bar get in the way?
Change the nuts to copper ones afterwards, that?s what VAG ones are like now…. you wont have as much aggro the next time. Unless your daring only renew the studs that might come out with the nuts when you undo the nuts.
Main problem with nuts on downpipe/manifold section are they are seized on and hard to get to - been soaked in WD40. Should I risk shearing more off - at least I would get them apart easily that way :twisted: . I'm getting the manifold remachined by a friend of a friend who does that sort of thing for a living, so assume no reason he couldn't redo all studs if needs be?
1983 1100 C
1983 1100 C
Guest user
Eventually hammered on a too small socket, some came out with the studs attached. Fortunately this was with the engine on the floor. Not sure I would have attempted it with engine in car. Don?t remember any of them being Allen sockets?
I also had an exhaust manifold stud missing and after welding bolts on, getting it glowing orange and failing to remove it had to drill and retap to fix it. Then a palaver with a pattern down pipe and genuine heat shield meant I sheard off another one. This was on the car and I had to drill it out and retap. Not fun on a concrete garage floor.
This is why VW changed to the c-clips. Now everyone who has them complains. If only they knew?..
A lot of non-standard size nuts - they seem to be between 11 and 12 mm, anyone got any ideas why? They don't fit any imperial size either. Going to refit with decent proper sized nuts so can undo in future with a rachet and without unbolting half of car :roll: .
Some of the studs came out with the nut, but most stayed in. I assume the struds are reusable or are they the use-once variety (all looked good condition)? If so any easy way of removing old studs?
1983 1100 C
1983 1100 C
![m6m62 in the usergroup ‘Old timer’ m6m62 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Good luck with it !
Mark
I'd just leave the old studs that are still in the head if they are in good condition and just replace those that came out if you want to. You could remove the rest but I'd just leave them as the penalty for snapping one or stripping the threads and still not being able to get them out would be mega
Definately get new copper nuts though.
I removed all the studs from the top of the cylinder head where the rocker cover bolts down, the 2 nut trick didnt work and just stripped threads. I used a monkey wrench/stilson to get them out.
Ross
1983 1100 C
1983 1100 C
Part number: N 900 850 01 ?0.28 + VAT
Manifold studs for cylinder head are…
partnumber: N 044 411 5 ?0.58 +VAT
GSF probably cheaper?
Ross
1983 1100 C
1983 1100 C
