T-CUT OR NOT T-CUT
(In Topic #72713)
![PD150 in the usergroup ‘Regular’ PD150 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
T-CUT OR NOT T-CUT
FOR SALE:1982 VW Golf 1.8 GTi (VW Classic Green Pearl)
2006 VW Touareg 2.5TDI (Ravenna Blue)Fully loaded
FOR SALE:2003 VW Golf PD150 (Reflex Silver)
172.5bhp/299.1lb ft (standard/no modifications)
1990 BMW M3 (US Model)
www.vagdrivers.net
www.vagdrivers.net
![alexh in the usergroup ‘Regular’ alexh in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Re: T-CUT OR NOT T-CUT
![Avatar](https://img.photobucket.com/albums/v241/Dub76/dub76.jpg)
![Dub76 in the usergroup ‘Local’ Dub76 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
ohh and it was an 82 mk1 van 1 owner 34k sold it to lad in lincolnshire
![lhasa in the usergroup ‘Old timer’ lhasa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
alexh said
NO, t cut is primitive(full of bad chemicals) use g3 and then if you have a lot of swirl marks use g10 and then a good quality wax(auto glym) and hey presto shiney car back
Not seen G3/G10 before. Are these 'off the shelf' products or trade only?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1983 1100 C
1983 1100 C
![turbtechnicsMK1 in the usergroup ‘Old timer’ turbtechnicsMK1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![G60RGE in the usergroup ‘Old timer’ G60RGE in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
they apply water onto the body as they do it cos if u rub too hard the paint will heat up and come off….just to warn u cos paint on mk1s is very thin…
im sure u can do it urself though,
![Wills in the usergroup ‘Regular’ Wills in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
www.vagdrivers.net
www.vagdrivers.net
![skid in the usergroup ‘Local’ skid in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
If you are dont mind spending some money try putting some Swissol or Zymol wax on the car …you will notice the difference 8O
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Farcella G3 great . But meant for professional use with the correct cutting mop on your machine , small areas say a minor blow in respray yes but a complete car by hand …..
T-CUT is or should i say was ! So good in fact that the chemicals [ammonia {smelly nappy} and more] have now been removed due to legislation , same story with garden pesticides . G3 and the like are cutting compounds -they remove a small layer of paint-so do it once and keep it polished or waxed to retain its original shine . I have seen cars T-Cutted so much that the original primer has started to show through .
Chudd….
![Clean in the usergroup ‘Newbie’ Clean in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
alexh said
skid auto glym do a wax but you cant buy it in your local halfords or motor factors. trade only as it only comes in 5 litre cans and it aint cheap but good it is
Zymol will give a magnificent finish and as it is water based it is less damaging to fragile paint work. The problem is it is very time consuming.
