Fed up!!!!
(In Topic #72542)
![littlekev in the usergroup ‘Local’ littlekev in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Fed up!!!!
The shell is completely bare and has brand new front and rear panels fitted and the rear arches repaired. I have loads of new parts including all fuel lines, accumulator, master cylinder, drums, frt shocks and strut tops, wheel bearings, hubs, goodridge hoses, genuine wings, 2 standard interiors … the list goes on.
I would have to get around ?1000 for everything but might have put everything seperately on Ebay but thats quite a lot of work. Should i persevere or sell everything?????????
1996 Gti Anniversary 8v Mystic Blue
1995 Gti 16v Fjord blue
I felt exactly the same when doing mine though once it came back from the paint shop - It flew together! If you are at this stage, all the hard work is done!
My Build Thread
![SIMAC in the usergroup ‘Local’ SIMAC in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Restoring a car is a long and winding road but it will be worth it. The early stages are the hardest as you seem to be going backwards rather than fowards. As Crazy says get the body work finished and start the reassembly process with all those shiny new parts and things will start to look alot better in more ways than one :wink:
Simon
'83 Mars Red GTI
![tallpete in the usergroup ‘Old timer’ tallpete in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Middle of a project, can't remember why you started this bl**dy job, ends too far away to see.
Finishing- all downhill, the ends in sight and you starting to see the finished picture.
Get yourself out of that middle section, it's a motivation killer, and you'll be fine.
Peter.
1980 1600 GTI, daily driver.
![Maniac in the usergroup ‘Old timer’ Maniac in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Keep at it littlekev, it'll all be worth it in the end when you got a nice shiny restored golf to drive around in and you can proudly say 'I restored that all myself!'
1983 White cabriolet GTi
Thanks for the encouragement
Sounds like you've got quite a lot of hard work and nasty bits out of the way. Once complete you will know that you have done a thorough job and that there should be no nasty surprises waiting for you - something you can never be a 100% sure of when buying a runner. If you're still unsure, mull it over for the next couple of weeks. Don't rush to get rid of it, I'd imagine January is never a good time to sell cars anyway.
Good luck
1983 1100 C
1983 1100 C
Life Member
Life Member
Insted I have a grotty 30 year old concrete garage with an asbestos roof and rotting woodwork to work on mine in. Luckily as the car's fairly short, there's enough room for a decent sized gap at the front of the car and a work bench. It does have electricity so I can run a heater in there, not that it makes any difference and is fairly dry excpet if it rains hard when the water runs under the door and floods the back corner :-(
I've now spent more on the car than what I bought it for but the sum doesn't seem to equal the car I now have!! I know that never stacks up but all time/effort has gone on keeping the car going, rather than improving it - certainly body wise.
Thats said (touching lots of wood!!) I don't think there's much else that can go wrong now. Picking up some new doors tomorrow (2nd hand new!) so can get round at last to getting rid of the old tin worm, perhaps only to sell the car?!
Anyway, I'd certainly when buying another MK1 spend a bit more money to buy a better one in the first place - unless of course I wanted to buy a project car to start with. That Helios Blue one on eBay would be the ticket but Santa has already been and gone for one year!
![Avatar](https://i281.photobucket.com/albums/kk235/woky_photos/mark1golf.jpg)
![woky in the usergroup ‘Paid Member’ woky in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![woky in the usergroup ‘Local’ woky in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1984 white s2 golf gti , 2006 golf gti
http://portal.campaignregister.co.uk/modules.php?name=Forums&file=viewtopic&t=319
seen it !! done it !!
If i had given up her in doors would have had no where to leave the Turkey to defrost this year !
Take a break then tackle it later maybe next month
Cheers Chudd……
Restoration takes a lot of time along and money to complete. However if you like doing it well that's another matter
![ChrisB in the usergroup ‘Old timer’ ChrisB in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If you are getting fed up with it then you might be tempted to cut corners and you will just regret it later. If its not your main car then whats the hurry?
I am beginning to seriously question whether I am doing the right thing keeping my Campaign as a runner / rolling restoration :cry: . For the second time in 6 months its left me completely stranded, luckily not far from home this time.
Unfortunately this time I have not idea what the problem is - it starts (reluctantly) then runs for a short while then just dies and won't restart for ages. By revving the nuts off it I was able to get it home once restarted (only a mile), but I was wincing all the way.
Looks like I have sparks so HT and distributor are probably OK. Fuel looks to be coming through too, so not sure what the problem is.
I fear its crud in the fuel system which may mean the filler neck has gone letting crap in or something equally drastic.
As the MX-5 is currently off the road with accident damage I'm effectively carless.
Its at times like this I question the logic of running two "classics" and not having access to a more reliable modern car. Classics always need something renewing on them in my experience.
Maybe its best to start with a shed and no illusions and renew EVERYTHING, rather than buy a so called "minter" but never being sure how well it was restored?
Keep at it Kev - you'll be glad you did, and trying to sell it now will probably lose you a shedload of cash. If you still feel the same way when the car is finished then by all means sell it - you should at least get decent money for it.
Chris
