Immobiliser fitting - best circuits to 'cut'?
![Screen Shot 2020-09-08 at 9.23.03 AM.png Screen Shot 2020-09-08 at 9.23.03 AM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1599571541/uploads/attachments/5f57865532ce8.png)
Not that expensive, and you can mount it after the Battery, One lead from the Battery to Big Post, one lead fro, Big post to starter solenoid, and the itty-bitty lead from your starter solenoid Used to "pick the relay" as the relay is grounded via the mounting bracket.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
paceman said
Looks like that will do the job, it won't fit in my nice relay/fuse box though!
No that is why I mounted it on the inner fender, as it shortens the run of wire to the starter…. IIRC it is good for about 100Amps… And the Dual Post is a good thing as from under the Bonnet, with the Car in Neutral, Barking or E-brake fully on Key in ignition and in the run position, shorting the two big posts on the relay spins the starter and starts the car…..
