Best way to Descale water pipe connections?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/WhatsApp%20Image%202019-08-22%20at%2008.jpeg)
![h3lter in the usergroup ‘Paid Member’ h3lter in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![h3lter in the usergroup ‘Local’ h3lter in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Systems already drained
Briano, I've got thebelt and tensioner in garage, it was on the list of to dos, luckily I hadn't got to it yet!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Anyways, make sure you get new injector seals as they can also go 'hard'.
Unless you are confident, I'd be tempted to get the bolts removed by a machine shop, as there is no margin for error. The bolts will be harder that the alloy of the head so it won't take much to mess it up. Not many jobs I wouldn't tackle, but I'd draw the line at that!
paceman said
My fuel injector inserts (83 GTI) don't look anything like that - mine are just plastic inserts….
VW change/improved/added things to the K-jet over time, early cars had slightly different injectors as later cars (84 ish) had air shroud injectors, air pipe from breather into the cylinder head between cylinder 3 and 4 so that is why there's some differences in the inserts.
Yours must be like this?
https://www.vwheritage.com/063133555a-insert-for-fuel-injector-18-vw-spare
Just check what's fitted to your engine before buying new stuff as I only know whats fitted to my engines.
yea they are more what i believe are on there, my cars a bit of a wierd one because its build date is 81 (according to boot sticker) and the reg date is 87 so i find some parts are bit of a mix when it comes to buying replacements.
its like this coolant flange, i can only find plastic inner rubber seal, however mines alloy. I jsut worry about how hot the head gets for that rubber to be ok
ta
I know that the plastic ones are the norm these days, and most reckon they are better.
Regarding parts, take a look at: https://volkswagen.7zap.com/en/rdw/golf/go/1983-7/
You can change models if it's not the right section.
![](https://uploads.tapatalk-cdn.com/20190114/274fb66d1493dca68f71d1f7904c1172.jpg)
Sent from my ONEPLUS A3003 using Tapatalk
Just check what's fitted to your engine before buying new stuff as I only know whats fitted to my engines.![]()
Thanks Mark, , that's what mine are like. Not that they need changing, just wanted to make sure he was getting the right ones!
and thanks for part, its the stud i needed for when its fixed!
love 5 mins jobs that turn into peshwari naans
https://www.vwheritage.com/027121631a-double-thread-stud-vw-spare
Holy Horse Hockey "HE double hockey sticks" Batman. Plastic Parts that connect a vibrating part(engine) to stationary things ie: Radiator or Heater Matrix's aren't better they were design change by bean counters…. I never had a metal water outlet deform and leak ever. I never had a metal outlet break off, or crack at the mounting ears in 20 years of Dieseling…..
The Bean Counter and or Engineers that re-designed that part should be fed ex-lax,shot, hung upside down by their privates , and handed a dull serated knife.
I really think that who ever re-designed Radiators and Heater cores with plastic tanks should be consigned to the firey pits of Hades as well…
Just to play devil's advocate I'd say that a rubber house wouldn't transfer that much vibration….
![](https://emoji.tapatalk-cdn.com/emoji6.png)
will then order whats needed and see where we go!
paceman said
Personally I'd stick with metal, but I've read a few comments that suggest the plastic ones are less prone to leaking where they mount to the head.
Just to play devil's advocate I'd say that a rubber house wouldn't transfer that much vibration….![]()
I have had to replace the front water outlet on my 90"s and I have had 3 of them 90's cabriolets, every 6-7 months. Hence the thread of mine "I still hate plastic parts." I have also had to replace the "T-Stat" outlets and the outlet on the head because it distorted, and started leaking past the seal.
Granted the "T-Stat" cover and the water outlet on the side didn't break as much as the front, I usually replaced those every 2 years. So much so that I kept spares of all 2 on hand.
Since I have replaced all of them with Metal ones I haven't had a leak or a break in 5 years since the total conversion of all to metal.
The difference is that I drive both of mine Daily, and that was 20-50 miles.
I drove a Diesel Golf for over 330Kmiles/20 years and never had a metal one leak or break.
![05072C9B-313E-4298-B18D-317C0961180C.jpeg 05072C9B-313E-4298-B18D-317C0961180C.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1547577051/uploads/attachments/5c3e26d9073bd.jpg)
It's crazy the things I have found bodged, surely there can't be many more 🙈
One of them was gorrilla glued in place!
Now to order along with the injector seals, however all coming up green not black??
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F190669091413
Do your fuel injectors have the top hat on the end?
If so buy the kit which replaces both seals..
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-GTI-MK2-GTI-16V-FUEL-INJECTOR-SEALS-x-8-C933/221233249484?fits=Model%3AGolf&epid=16006366738&hash=item3382877ccc:g:MhQAAMXQAF5RgpY2
Early type injectors
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-SCIROCCO-STORM-FUEL-INJECTOR-VALVE-BOSCH-049133551A-A888/191630779767?epid=248676364&hash=item2c9e15a577:g:PYEAAOSwDNdVo8rn
Later air shroud injectors, you will have a air pipe in between cyinders 3 and 4.
https://www.ebay.co.uk/itm/4X-BOSCH-FUEL-INJECTOR-VW-GOLF-MK-1-86-93-2-84-91-JETTA-2-84-91-1-8/382350402163?hash=item5905dc2273
While I only need 2 o-rings per injector on the digi, I can usually get them in a set of 8 for about 5 dollars, or buy 4 "KIT'S" for about 15 bucks per kit. I being the cost effective illegitimate son (read Cheap Bastiche). I opt for the set of 8 for 5 .
See this thread: CIS Injector Cleaning, Seal and Holder Replacement
He shows using the green seals as well as the Berryman's cleaning the injector to get a conical spray pattern.
It's just 4 seals I need and 4 holders
Well that's all that has come out lol
Assume these are the badgers I need
Tip for fitting them, get some carb cleaner and spray them, it lubricates them so they are easier to get on, then evaporates.
Also works for wishbone bushes…
Briano - tell me more about this injector cleaner stuff. Does it thread on to the injector as I know they need a certain amount of pressure to open (unlike electronic fuel injection).
These little gits are £12-40 each on eBay!!
But 19cents on this www
Ever heard of them?
https://www.fcpeuro.com/products/audi-volkswagen-fuel-injector-sleeve-063133555a
