Anyone fitted a new headlining?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/NK785B-1-1.jpg)
![Malcolm in the usergroup ‘Paid Member’ Malcolm in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Malcolm in the usergroup ‘Old timer’ Malcolm in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Re:
Hi. You are absolutely correct, trim the tubes as required, make sure you leave enough material to maintain the stitching.Pete M said
Sent from my E5823 using Tapatalk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160228_142150000_iOS.jpg)
![Pete M in the usergroup ‘Local’ Pete M in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
I removed the windscreen myself by tucking the inside part of the seal under the spot weld lip a little at at time, starting in the top corner and then equal amounts each side of the start point, took about half and hour.
The headlining I found quite easy to do using the instructions you guys recommended and the 3M Refit tape. I would have really struggled with contact adhesive, spray or from a tube.
I attached about 6 inches at the front and then the same at the rear, the completed the windscreen area. After that was complete I did the sides and finished with the rear C pillars.
I found i quite straightforward and would say if you have the patience and use the tape go for it.
Thanks for all the help folks.
![262A8FCB-348B-480D-B47F-7A5D4B4DD02B.jpeg 262A8FCB-348B-480D-B47F-7A5D4B4DD02B.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1524118874/uploads/attachments/5ad83559812b2.jpg)
![14E9F9AE-A4CC-4AE5-AE25-6029B4C67255.jpeg 14E9F9AE-A4CC-4AE5-AE25-6029B4C67255.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1524118879/uploads/attachments/5ad8355d954d6.jpg)
![DAC04757-C0F2-48BC-8331-891A4861DAD4.jpeg DAC04757-C0F2-48BC-8331-891A4861DAD4.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1524118883/uploads/attachments/5ad83561adbb8.jpg)
Re:
Brilliant well done, glad you used the 3M fixit tape, looks a good job done.Pete M said
The tape will be very useful for other jobs in your restoration.
Malcolm
