Cabby Gti
You can use wet suit material - from the upper arms/lower leg sections.
Take them to a clothing alteration place and they can insert large plastic zips so you can wrap them around the coil over and threaded section and zip them up water tight,
The wet suit material will flex with the movements of the coil over but not tear or split. The large plastic zipper won't rust either. You can then easily remove them to clean etc or show off you nice shiny coil overs at show time. Different solution but effective!
Cabby Gti
Cabby Gti
Checkout a diving or surf shop. There has to be a wet suit manufacturer in the UK.
Contact them and they'll probably make you up a set or at least be able to supply you with the wet suit material and zips.
You could look at buying a second hand wet suit and use material from that.
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
Cabby Gti
