Mk1 running badly with choke all the way out
(In Topic #208436)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/volkswagen_golf_mk1_yellow_front_view_107928_1920x1080.jpg)
![Mk1satinblack1.8carb in the usergroup ‘Regular’ Mk1satinblack1.8carb in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Running badly when driving (stuttering kind of) and when coming to a stop it will sometimes stall or if it doesn't it will idle really low and take a while to build up to the right revs, PLEASE HELP
When was it last serviced, Plug, HT leads, dissy cap, rotor arm?
Has it does this before?
What is the fuel filler neck like?
Is there any bits in the fuel filter and when was it last changed?
Which carb do you have, Webber or original Pierburg?
![Chiz_Connor in the usergroup ‘Regular’ Chiz_Connor in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I've got a similar problem at the minute to what you are describing.
Thought it was initially a fuel starvation/carb issue but I'm now thinking its electrical as the problem with stuttering only happens when the engine is under load (when in neutral I can freely rev the car without it missing a beat). Firstly, I changed the dizzy cap and rotor arm, problem still persists, I am now thinking Ht leads and Ignition coil, so I have ordered them up and gonna give changing those for new ones a go.
I will let you know if the new parts fix the problem!
1992 Clipper Cab converted to single headlights
Powered by 1.9 TSR Donnington gasflowed engine
4-1 manifold
Stainless steel custom exhaust system.
Now rocking a fresh new mohair roof and respray 🤙🏼
4-1 manifold
Will check fuel filter tomorrow, could it be a carburetor problem? Perhaps it's blocked somehow or just has something flying around in it.
It does have original pierburg carbs at the moment but hoping to get Weber carbs soon. Strange how the Revs completely drop when I put the clutch in to change down gear even when I'm going 50ish but it doesn't happen every time only now and again. When it happens and I come to a stop and it's idling really low like nearly stalling the revs will come back up really slowly and then it won't happen again for another 10 minutes
I fitted the new HT leads and ignition coil before when I got back from work but to no avail, the same problem persists. I'm thinking now it has to be a carb/fuelling issue so am going to have a play with the mixture. I have also read somewhere that it could be being caused by a leak in the vacuum system from the vacuum advance???
4-1 manifold
4-1 manifold
I did notice that where my brake servo pipe attached to the inlet manifold it had been bodged with a new non standard peice of rubber tubing and upon removing found loose bits of the rubber pipe inside (perished).. don't know whether this could be my problem? Does anyone know what relation a problem with the tubing between my manifold and brake servo would be to the running of the car? I am going to replace the incriminating peice of pipe work regardless but would be good if it fixed my problem at the same time!
4-1 manifold
4-1 manifold
![Daytona in the usergroup ‘Paid Member’ Daytona in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Daytona in the usergroup ‘Old timer’ Daytona in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Just a long shot:
Try disconnecting a flexible part of the fuel line in near the carb' and carefully blowing back towards the tank. It should be an easy blow and you should hear bubbling from the tank area. Mine was almost completely blocked by rubbish and after a big hard blow it then suddenly freed and all was good after, but need to clean out tank/pipe if this was the symptom. I had similar problems to yours, and like you,. thought it was electrical.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1552036688.jpg)
![Backinblack in the usergroup ‘Old timer’ Backinblack in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
First leaking servo pipe will be a big issue for both running the engine and more importantly stopping !!! It will cause the mixture to run lean as extra air is getting into the system after the carbs and if someone has made it richer to compensate then this will mean it is too rich when the choke is out.
One post mentioned doing 50 with choke issues. I would expect the engine to be warm enough not to need choke by this speed.
If plugs are recent check the gap or if old change them. Plugs work much harder in the cold as with all the extra wet fuel coming in they can get flooded a little so if the have a wide gap and weak spark then it will not help at low revs as the fuel will effectively smother the spark at low revs due to richer running.
Dizzy Ht etc all mentioned good plan but the low cost options mentioned may help in the shorter term.
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
most of the checks in here will still apply if its otherwise untouched, the idle and mixture adjustments are the last thing you mess with on these make sure its 100% tip top before you do that:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14917
have a look at the flange and steady bracket as per the above links anyway though. also these carbs are sensitive to cold weather so you really need the warm air feed system to be 100% working otherwise it'll cut out. theres a warm air feed pipe from the bottom of the airbox to a shroud round the exhaust manifold make sure that side is all good. then in the domed bit on the airbox theres a flap which should open when the carb is running, if you remove the inlet pipe to it you can see inside
The rubber mount between my inlet manifold and where my Weber fitment kit starts has split down one side but isn't noticeable when still or on idle, however, when under load (or when I move the carb around by hand) you can see the split on one side.
Touch wood, once this is replaced it works again haha
4-1 manifold
4-1 manifold
4-1 manifold
4-1 manifold
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1481644671/uploads/attachments/58501a7e1fb5c.jpg)
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1481644674/uploads/attachments/58501a80cf826.jpg)
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1481644676/uploads/attachments/58501a835c20d.jpg)
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1481644679/uploads/attachments/58501a861e5fc.jpg)
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1481644681/uploads/attachments/58501a88b8973.jpg)
Also in the last picture with your fuel filter there is a normal jubilee clip used, it better to use a fuel line clamp as they clamp all the way around while jubilee clips only clamp 1 side and you can get a fuel leak and that's not a good idea where your fuel lines are running!
Fuel pipe clamp looks like this, lots of places sell them, link just a picture.
http://www.ebay.co.uk/itm/MINI-FUEL-LINE-JUBILEE-HOSE-CLIP-CLAMP-DIESEL-PETROL-PIPE-ALL-SIZES-IN-STOCK-/300709654222
And yes that's a Webber carb.
Picture of how I've routed my fuel lines and filter but it's on a Mk1 Scirocco so other bits a carb very slightly different from yours.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1555621/IMG_3735_zpshwacwfwa.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1555621/IMG_3732_zpsqzexdhbs.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1555621/IMG_3731_zpsnynnhxqv.jpg)
Put the new flange on yesterday and its been running spot on since, thank you for the suggestion, so glad its done so now I can get on with other stuff.
