Idiot newby with usual problem
Chairman
Here is the one you want for a 55l tank, and the new one is a tin top, shows you how much you have to mod (and hopefully the right one for your car - my old one)
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
just to confirm for anyone reading this that the cabrio up to 1983 use the same fuel tank and filler neck as the mk1 tintop, then from 84 onwards they got the larger tank, shallower boot with space save spare and shorter filler neck
Chairman
Follow us on:
Follow us on:
Chairman
Part #: 171201129F
Follow us on:
Follow us on:
It's just really handy having ETKA on your laptop. Though
Cheers fella
Unless you got new links and a code for me Lols…
I've tried all sorts to no avail ..
Mine is the same as yours So I need to get a replacement as well.
Edit: Think I'm going to buy a flexible universal fuel neck to tank pipe cut to appropriate length and use the short neck
Last edit: by AlexG
Chairman
Follow us on:
Follow us on:
Dam and blast……
Here's mine with a hole in it, I'm changing the engine and fitting new injectors and don't want grit and water in my fuel system. It does look the same as yours.
I think heating it up and bending the pipe will just end up crushing the bit of pipe which is bent.
You can see the difference
Cut and welded
Trial fit yesterday and all good so just getting painted now.
