'90 Cabrio Karmann
Am searching for a new OG VW logoed front green tinted windscreen
Will buy a NOS front windscreen seal as well
The repro seal and windscreen are letting in water so badly that under heavy rain a leak in the fuse box keeps the wipers going even if I switch them off..
My finished badges with my own repro badge refurbish decal set will be put on on Wednesday
BerT3
The end result
Decided to not install the other badges since I like symmetry
Photof the flattened 5 speed shifter relay which made it sometimes difficult to shift down from 3 to 2 and from 5 to 4
BerT3
Liking the badge symmetry!!  :thumbs:
The windscreen will be replaced next week
I really wanted to find an OG green tinted one with white VW stamp but after hunting for a couple of weeks and contacting over 10 sources I decided to fit a good quality repro one
Escpecially after I had a stone chip yesterday from a small rock on the highway
The car leaks from under the windscreen seal and has some rust bubbles under the paint as a result - that area will be resprayed and the windscreen fitted with a NOS seal
I really wanted to cover this before I put in the new second hand carpet
BerT3
The window is out - found an OG one
Found some rust under there - will be patched - sealed and repainted
Bought a NOS rear vieuw mirror to replace the glued on generic one
BerT3
Always a shock what you can find lurking under rubbers and trim!
Got the car back from the body shop
Had to weld in new material - repaint the entire wiper area
Found an OG window in The Netherlands
Installed with a NOS window seal and a NOS rear view mirror from France
New is replacing the smelly and leaky interior heater
BerT3
Bought some wheels for the winter
Golf 3 rims with trim rings and caps
6 x 15" ET45 with Continental Wintersport tires
BerT3
Last edit: by BerT3
Next on the list - clean and change out the heater matrix
Luckily I had a spare one which will be cleaned and assembled together with the new heater matrix
BTW can I get it from under there whithout taking the dash out ?
BerT3
Changed the air filter setup
Cut of a small part of the remaining part where the hot exhaust air mixes with the cold intake air
Used a Polo 86C air intake tube - heated it up - stretched it over a coca cola can and pushed it oval and over the remaining oval part of the OG air filter housing
Even managed to use the OG clip and screw of the Polo part
Note that the hot air shield over the exhaust manifold was already removed
All done to get as cold air in a possible for the slightly hotter running engine on LPG
BerT3
How did you do the badges? They look brilliant.
Bought me this set on Ebay
No idea of I will use them but for the amount I paid I cant refurbish them myself
BBS RA 15x6" ET 35 with polished lips and repainted webs
BerT3
Finished the interior heater last weekend
Split it open - cleaned it all out - removed all seals - put in new foam
Installed the new heater core - NOS tubes - NOS go through the bulhead grommet and some spare OG blue clipses I had from another heater core
Quite a PITA to install but with a little bit of patience everything went in fine
Now I do have a ver good working unit that doesn't smell when heated and doesn't leak
For future reference - those NOS OG VW hoses are just rebranded Gates hoses !
BerT3
Great looking cabby!
Nice to see an other 'Belg' on there  :thumbs:
I also installed a NOS gas cable cable grommet since the cable was attached with zip ties
No idea what the PO was thinking…
On the other hand I found a solution of my very slightly dancing idle
To accomodate with the LPG setup the breather inlet tube at the air filter was closed up and the tube rerouted with a generic oil hose to a hole in the side of the air filter
Since the engine now breathed in front of the K&N air filter it got very oily
The rotation pulses of the engines with hot oily air mixed up with cold fresh intake air kept the idle slightly unsteady
I plugged the hole that was made and rerouted the oil hose to the ground
Now I do have a very and correct idle !
I ordered a Moroso oil beather catch can to collect the evapoured oil
BerT3
Made me a bracket for the oil breather
Rerouted the breather line - replaced the water lines for the LPG evapourater as well
Some photos
BerT3
Had a quick look on how the OG BBS RA 15" suit the car
Quite like it :)BerT3
Last edit: by BerT3
Finally took the time to change out the carpet
Removed the old one which had several holes - cigarette burns etc.
Vaccuum cleaned all dirt - found some old coins from before the Euro
Used new under sound deadening from VW Heritage
Reused all correct clipses - the round ones I had NOS
Everything went in just fine
The Corrado tillable seats are a PITA to get in though
BerT3
Did some tinkering with that carburetor last weekend
Finally getting there to the point it drives like a newisch car
Ordered some spare and missing parts to keep it al OG under that bonnet
BerT3
Good progress going on in here :) if your still running the perburg then it will need a bit of tinkering to get right
