2.0 16V ABF conversion first impressions
(In Topic #185588)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/K19OLF%20Avatar.jpg)
![Craigt in the usergroup ‘Paid Member’ Craigt in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Craigt in the usergroup ‘Old timer’ Craigt in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
collected yesterday...
Anyhoo, collected yesterday from Tsr, who gave me the car fully valeted ready to drive away, well as far as a teaspoonful of fuel will take you. Filled up which took 56 litres at a cost of £76, the most I've ever managed to get into the tank.
The car remains every bit as drivable, with the only irritant is the level of noise coming from the fuel pump. That will need sorted. A slight stutter on motorway neutral throttle but otherwise a very good arrangement. Power is as expected, a lot more lively that the previous engine and box and the car seems like a completely different machine. I took the car north via Wales and the car is now the machine that all mk1s should go like, if that's your thing.
I was impressed with my mpg on the way down as I got around 38, but the huge surprise was on the way back ipi filled up for the second time only when I got home exactly 460miles from one tank that took 46.7litres to fill up again. Some quick mental arithmetic I burnt around ten gallons meaning I got an astounding c45mpg. Trust me when I say, I put the car through its paces on back roads, motorway and spent several miles on busy town roads across Kidderminster, Bridgnorth, Worcester until I eventually rejoined the motorway at Ellesmere Port. The car had three people and a bag of cotswold gravel for the garden.
Am I happy with the work? Yes. Slightly over budget but the work under the bonnet is top class. I've been smiling since the engine fired up for the first time.
Would I recommend this conversion? Yes.
TSR?, yes.
Overall, at this mpg, the conversion will pay for itself in around another 80k miles. :-0 but the fun factor has more than doubled, which I can't really put a price on. :-)
![huw169 in the usergroup ‘Paid Member’ huw169 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![huw169 in the usergroup ‘Old timer’ huw169 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
My current mk1 had to have a special adapted downpipe manufactured due to my power steering set up.
They used a combination of the original cast unit then a manufactured downpipe. I've yet to get a good look down there to see exactly what has been done.
The guys down there aren't the most forthcoming so I'll guess I'll have to find out these things for myself when I get around to detailing and cleaning up in the engine bay.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2MK1%20owners%20club%20avatar%20100x100.jpeg)
![Desperado in the usergroup ‘Paid Member’ Desperado in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Desperado in the usergroup ‘Local’ Desperado in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Are you still running K jet or did you swap to the newer set up?
My New Year's resolutions are: 1. Stop making lists. B. Be more consistent. 7. Learn to count.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/008_zpse29681e9.jpg)
![Melteddrummer in the usergroup ‘Moderators’ Melteddrummer in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Melteddrummer in the usergroup ‘Paid Member’ Melteddrummer in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Melteddrummer in the usergroup ‘Local hero’ Melteddrummer in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![chipster2407 in the usergroup ‘Old timer’ chipster2407 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Especially of the downpipe
The previous set up was a carb, this is the full mk3 system. Had to have a new tank and full fuelling system installed. Ecu is in the scuttle tray. Looks pretty modern in there.Desperado said
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
I'll see if I can get pics up.
huw169 said
Yes, pics..
Especially of the downpipe![]()
Huw, I took a look at this today. I have the original cast iron manifold, with a stainless two pipe section to the underside then onto the new exhaust.
I still reckon that you could buy one from Tsr, this forum or the sometimes trusty eBay. I doubt if there is a DIY option, unless this is your skill set.
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
Oops, can anyone lift the picture off and insert on this thread? Thanks… I'll really need to get this photo malarkey sorted…
The fuelling is certainly on the radar, the throttle feels a little dull, press a bit further and the thing goes into warp mode. (well, sort of
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
I'll get pics of this too.
Can't wait to get mine done now. I'm going to give the exhaust downpipe a go myself as I've started. Hardest bit about this conversion is getting an exhaust that fits..
if its a facet or similar then it should be ok
I'll get better ones once I get the car on the ramp.
http://s1290.photobucket.com/user/craigt007/library/Mobile%20Uploads
Your suspension top mounts also look past there best.
i can see the pump is mounted on rubber bobbins plus is in a rubber sleeve so should be well isolated
