1.5 Carb issues :-(
Do I need a compressor or could I use tyre pressure and some sort of attachment ??
The car runs ok for a min or so and then just dies, its a little bit harder to restart after its stalled but not much.
I am to try 2 things
1. keep the recs up and see what happens
2. bypass the tank and pipes by running the petrol to the pump with a milk bottle
I might also try and drive it round my estate for the first time if I can.
Website Manager
lhasadreams said
Can you keep her running by pulling the choke out a bit ?
I think so Ade, I will start it later as I'm gardening :-(
I will report back.
It runs fine ish for s while and then dies after anything upto 10 mins.
When I try to restart it its not easy and the revs go all over the place and it takes a few mins to get going ?????
Ade said it was all about the float and I'm presuming that in my service kit for the Weber that there is something that fixes it.
Next job IMO is do the filler neck etc. and get the tank cleaned and pipes blown through with a new filter in before thinking about full car service then carb.
Is that the answer :-)
Website Manager
1985 Cabriolet GL
1985 Cabriolet GL
I never got back to the car after Saturday as I was too busy, I will wait for the filler neck and the rest of the bits to arrive from Funk hopefully this week.
Then do the neck and fuel tank clean etc.
Then see how it runs.
Depending on the running, if its well enough, I will pop it down to my friendly garage and get a full service and timing belt done, only using the garage as I like the book stamped. While there, they can do the oil sump and rocker rubber gaskets.
Then……………………………………….
I have Redex and I will check the relay, Jules
Massbad69 said
and
Oops, I should sell them as super rare items.
1985 Cabriolet GL
Can't do anything until I get the filler neck etc and do that first :-(
Next thing to try is condenser and points.
Struggling :-(
Definitely feel your pain- got my car last year (a clipper running a weber of unknown model…great!) and wouldn't run as soon as I pulled round the corner from where I bought it. Wasn't pleased to say the least.
I'd had no idea where to start and did the electrical route (plugs, hts, dizzy, rotor etc) and then moved onto the tank (new one, neck, flush the lines, new pump, inline etc) as it was apparent it was full of crud.
Think it was the return from the carb in the end. Cos someone put the larger carb on the car I don't think it was ever setup right and although it could run (often cutting out due to crud in the tank blocking the inline) it seemed to starve itself of the fuel and die or just rough idle.
After much trial and error over the best part of 4 months I then restricted the flow back in the return (creating a jet if you like). I did this via a restriction using a mig welding tip (bought a few from ebay for a couple of quid- added a y piece (which I picked up from halfords- can't remember which one but there's only 2 they have…can have a look if you need me too) on the return and added this into the line and crimped it down with a tie.
My explanation is probably shocking, but this is what I did- see the diagram here sciroccoregisterforum.co.uk • View topic - Fuel starvation weber carb)
Its worked for me and definately worth a go as it was only a couple of quid. Would say if you've cleaned the tank and the necks good it's worth a punt. It'll still require trial and error (mainly nipping the mig tip return until the jets as needed- and also possibly getting someone to setup the carb following…something I couldn't do as my skills are similarl to a goldfish).
My cars in getting its mot but should you need a mig tip, still got a spare so drop me a pm and I'll send you one or if you need a pic of mine more than happy to help. I'm in Bristol, so gather not local- if not would have given you a hand…although I'm no mechanic so probably better anyhow
May not work but definatly worth a try I recon.
Good luck.
I tried to start the car last night and it wouldnt even fire.
My mate is coming tonight to hopefully do the points and condenser and timing.
I think he wants to do a gravity fuel feed direct into the carb, to eliminate the fuel system and see if it makes any difference.
I am struggling tbh as I have no idea at all, so if my mate can't sort it, then its bin it or send it to a garage £££££££££££££££££££££££££££££££££££££££££££
