Adaptor sleeve on steering column Will. Not. Budge!
(In Topic #242680)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/3avatar.png)
![meltingdog in the usergroup ‘Local’ meltingdog in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
To get to it I have to remove the steering wheel and adaptor sleeve that's on the steering column. This is on a splined shaft and is meant to slide off.
It simply will not budge.
I've tried using a puller tool, lots of WD-40, and heat. Hell, I even attached a rattle gun to the puller tool to try and get it to move.
It simply won't budge. Not even a millimeter. It's gotten to the point where I'm actually damaging the shaft and outside of the sleeve trying to pull it.
This is driving me insane. What can I do?
![Screen Shot 2024-05-13 at 9.25.55 AM.png Screen Shot 2024-05-13 at 9.25.55 AM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1715606836/uploads/attachments/66421532610ed.png)
Also you might get to a breakers, and take the Inner shaft out of a Breaker that is correct. You may also need to take the Turns and wiper stalk as well.
Last edit: by Briano1234
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cool_flare.png)
![golfy1 in the usergroup ‘Local’ golfy1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Briano1234 said
Have you tried a wheel bearing puller? OPPS typo Bearing separator.
Sorry for the late reply.
Yep the bearing splitter worked a treat for me. Thanks!
