BBS RS/BC Coilover Rubbing?
(In Topic #242823)
Recently put some BC coilovers and BBS RS on my cabriolet and when i reverse i get a rubbing noise from my rear passenger side. The ride height clears the arch so it’s not rubbing there but can’t seem to pin where it’s rubbing.
Any ideas where it could be coming from?
Thanks!
With no adjustment of the coil-overs (camber) they must be fitted correctly. Axle offset to one side a little?
I'm running ET25 with 195 50 15s with no issues.
You may need to run a wheel or stub axle spacer to give you the clearance with your wheel / tyre combo.
Cheers Tron
Decades ago when I bought a set of wider tires for my Diesel Bunny (yes you call it a GOLF) They only rubbed on the inner fender on a lock to lock turn and in hard turns in parallel parking. Otherwise they were a Joy to drive on.
