The White ace
Main supports nurserted ready to be bolted together , just making a jig for the 3 supports then onto the main rotation part
A little more done on the roll over jig , looking forward to actual mounting it to the car
Started putting together the main pivotal points
Small update jig all painted up ready to go
Both front and rear mounts on going to start looking at removing the entire rear beam after adding the main post of the jig this week.
Got the rear beam off , found one or two holes in the shell ☹️ made some sketches at work , abit of cad then onto the laser
Progression in Started in making the rear beam triangular kit
So after looking at the steering column I not a fan of the bracket so Im going to change it completely where is adjustable and bolted and where I use the inner shaft only
Even got shiny bias pedal box that should make things cleaner
So I can't do anything to the rear beam until material arrives but I have stripped the steering column for what I need. Plus the post man has delivered my removable steering boss so can make a start and get it on the lathe.
Alittle update , Lots of parts Ordered be plenty of billet components throughout the thread❤️
Meterial has also came for the rear beam so another job on the lathe when i get 5
A little machining this evening hopefully get this steering column sorted this week
Removable Steering wheel column is ready ,hopefully get this mocked up in the shell tommorow so I can move on and look at the bias pedal box mounting
