FUEL PUMP RELAY
(In Topic #242510)
Help!
Any help or advice would be appreciated!
Ta,
Ross
I have taken the top off my relay and had a look inside. As well as the relay, there is a 555 timer circuit which switches the relay when a specific voltage is reached across one of the capacitors.
This is repeated ad infinitum whilst the engine is producing a spark. There is no pressure transducer in the fuel circuit to modify the fuel delivery. It seems that once the required fuel pressure is reached a valve opens in the fuel distributor and the excess fuel is fed back to the tank via the return pipe. Therefore the fuel relay should always be running - and will be clicking - whilst the engine is running, and therefore fuel is always being pumped. The frequency of the relay will be dependant on the components in the 555 timer circuit.
This is supposed to be the safety feature I was initially worried about. That the fuel pump wouldn't switch off in an accident - it does rely on the engine stopping tho'. If the engine is still running in an accident it is still pumping fuel at goodness know how many bar
Does anybody disagree with this analysis?
Everything you ever needed to know about fuel pump relays:
https://www.cabby-info.com/files/electrical/Relays_Kjetronic.pdf
