Fuel gauge still not working
(In Topic #241502)
![adolf in the usergroup ‘Local’ adolf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
One of the last job really was the LCD readout not behaving - I've taken the executive decision to leave it alone.(for now anyway).
The other last/biggy job was the fuel gauge which gave no reading. I've put a 9v battery over the screws holding gauge (with aid an additional length of wire) behind cluster and gauge moved out to 3/4 so that was ok. I've cleaned the connections of the fuel gauge nuts to the myler with electrical contact cleaner. I also got a reading of 9.89v and 10.05v on the 10v stabiliser - checked it twice.
Guess only issue is a break in the violet/black wire between the fuel sender and the instrument multiplug - or - the sender itself is in-op.
Job for new year
MK1 Golf GTi Campaign:Alpine White, Vauxhall Omega MV6, Alpina B10 3.3 Touring, Dolomite Sprint, MG ZT V6, Volvo T5 R estate
![6C2B5B6F-1CA5-44CA-A93C-6B7F5206CD7F.jpeg 6C2B5B6F-1CA5-44CA-A93C-6B7F5206CD7F.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1687115034/uploads/attachments/648f551793171.jpg)
Using the 9Vdc battery place the ground on the brown wire, and the + on the violet.
or measure the resistance between the pin on the connector to the back of the gauge or violet wire to the connector.
Your gauge should be at 3/4 of a tank. If not then wiring issue.
If it moves then it is the sender.
Here is a how to link about looking into repairing your sender.
https://www.volkswagenownersclub.com/threads/repairing-your-fuel-sending-unit.78890/#post-600458
Your sending unit is varying the ground potential to your meter. So make sure that you have a good ground to the sender plate.
3 things :
Faulty sender unit in tank
Wiring issue between plug and fuse box
Still got MFA to sort 😏
![IMG_7540.jpeg IMG_7540.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1713688086/uploads/attachments/6624ce14dcdbc.jpg)
Bad earth
![Jettaxl in the usergroup ‘Regular’ Jettaxl in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I've done new earths and checked and checked again.
Sure it'll be something stupid but was getting tired of it so left it for now.
![search.png search.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1714252787/uploads/attachments/662d6bf28a91b.png)
quick search
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=parts-wanted_2%2Fmotometer-mfa-circuit
lcd
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fpistolpete-s-mars-red
