Last edit: by Roach
Gonna pull all the pipe work off and check for blockages I think.
Bud Don't chuck the small block!  just work at it and you will get there.:thumbs:remove the thermostat and see if water circulates first as that is easy.
Last edit: by Roach
Last edit: by Roach
The only experience I've had with these was a Mk1 Polo I once had.
 There was a bleeder for the coolant on the heater if I remember correctly, a small white screw in plug that you removed, filled the system until coolant appeared there, then put it back and topped up.
Only a thought.
Endless issues.
Have you felt the pipes if they are all getting hot around the same temperature
Sent from my AC2003 using Tapatalk
