Window keeps getting scratched
(In Topic #241506)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/forks.png)
![Terrymoyce87 in the usergroup ‘Paid Member’ Terrymoyce87 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Terrymoyce87 in the usergroup ‘Regular’ Terrymoyce87 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Every time I lower window down and then back up I seem to be getting scratches on it.
Anyone had this issue?
I've removed the door card felt around can't feel anything. Cleaned the plastic at the top even soaked the glass in WD40 for a bit and sent it up and down can't find the problem
Grrrrr any advice would be helpful thanks
Sent from my CLT-L09 using Tapatalk
It's a cabby forgot to mention. The scratches seem to be all over the glass not only on one place and a couple are shaped like a C
I originally thought someone scratched there name into it but it's inside the car not outside
Here is a snap of the scrapers and the glass, this is the rears but the fronts are the same as well.
![Screen Shot 2024-01-23 at 12.18.34 PM.png Screen Shot 2024-01-23 at 12.18.34 PM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1706030385/uploads/attachments/65aff5311ab56.png)
Were are the scratches specifically. In the middle or the front edge, or the rear. a picture of said scratches may clue me in to where the issue is.
I know a bit, as I swapped a 89 Cabriolet door over for a 93, and had to make some cuts.
![](https://uploads.tapatalk-cdn.com/20240211/792dacd550204f4370e85bd17134d909.jpg)
![](https://uploads.tapatalk-cdn.com/20240211/1ff9749805455c5bf851b050dae503e6.jpg)
![](https://uploads.tapatalk-cdn.com/20240211/736134143525a4124bfbf37d988226b3.jpg)
Sent from my Pixel 8 using Tapatalk
You should see what is doing it. Personally that looks to be more of a Vandal than what I would expect from a mechanical scratch.
I thought the same but it's on the inside of the glass which has puzzled me
Need to fix it before I start looking for a new glass. Looks green tinted
