Din HT LEADS switch to Pins
(In Topic #240892)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/chess.png)
![bugsyboi in the usergroup ‘Regular’ bugsyboi in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Swapping leads and distributor for dins to pins? Is it possible?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/zender%20avatar.jpg)
![bacardincoke in the usergroup ‘Old timer’ bacardincoke in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
There'll be other numbers present, the one starting 0 237 02* *** or similar is the one I'm referring to.
Should be able to identify if it's correct to your engine (presuming it's a 1.8 DX, if not add what it is) and the Bosch cap / rotor numbers / leads that correspond to it.
It's best to do those sort of jobs yourself then you know it's right, you don't have to check what they have done and it's saves you money..
Check what type of connection you have with the coil as that's also probably the din type connection and the pin leads won't work very well.
Did the garage fit new spark plugs, rotor arm and dissy cap?
84 is a change over year so that may be why the garage got it wrong?
https://www.ebay.co.uk/itm/335027171779?fits=Car+Make%3AVW&hash=item4e012cf1c3:g:5PUAAOSwRWxlAVU3&amdata=enc%3AAQAIAAAAwJRz%2FSi4Ucll6NDzI7MRTH8yA%2B1hv%2F2GDDgpKCrQOhhPLAjlMv5rRf8Tm1xB4x3W3iezuBopITtlagg61xQ91QOooB7uQgNl3LWPaHH%2FW6WoYZURm5I80TCYlJUrluZcnx6eaampt0K3sD7pYy2dXeAY5mNosIzoB2BW%2BaTU2eZT3nMGwwgTOxpaEyEBtxVbQvO4jBOUw%2BOFGQVK20YUSGRQAvg%2BxuCWs0MbTpaHEu%2BPG2reWi%2BhW%2Bss7IVv6jXqxA%3D%3D%7Ctkp%3ABk9SR5jhm-vgYg
