DIY Fuel pressure test gauge
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/leech%20kr.jpg)
Regional Host NE
![nicci21paul in the usergroup ‘Paid Member’ nicci21paul in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![nicci21paul in the usergroup ‘Regional Hosts’ nicci21paul in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![nicci21paul in the usergroup ‘Local hero’ nicci21paul in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re: Re: Re: Re: Re: DIY Fuel pressure test gauge
How to....
When you can help out hands on puts the smile on a members face and your own self satisfactionnicci21paul said
That is Mark in the picture not myselfnicci21paul said
Mark Dempseys rivagenicci21paul said
End result absolutely mint dx in a stunning rivagenicci21paul said
Two parts just had one to bits today must try hardergregpank said
Good news is all the parts turned up and have assembled the kit.
Bad news is i cant separate these two parts on the metering head. Im just double checking this in fact two parts and not one?
Sent from my SM-G975F using Tapatalk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0971.jpg)
![gregpank in the usergroup ‘Paid Member’ gregpank in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![gregpank in the usergroup ‘Local’ gregpank in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Nice looking motor there!
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
PlusGas Formula A Dismantling Lubricant 400ml - Screwfix
Here’s what happened…
1. As before had to jump the pump, lift the metering plate to get fuel to the injectors for 20/30 seconds, then she eventually started.
(Its 26 degrees in the garage today at 4.13pm
![](https://emoji.tapatalk-cdn.com/emoji28.png)
[Also worth noting i have a TSR modified 1.6EG bored out to 1680cc so sometimes the manual figures are a bit off for me…]
Cold start is connected as is WUR electrical plug.
2. On cold start got 4.65bar, idle 1100rpm, tap open
3. Turned the tap off - no difference[!?]. Still 4.65bar. Reopened tap.
4. Let it run for 10mins, still 4.65b
5. Turned it off, pressure fell to 2.6b
6. Waited 30 secs, started up again first time, 4.65b
7. Switched it off. After 10mins - 1.3b
8. Switched it on, 4.65b but now idle is 1500rpm.
Couple of revs, dropped to 1400, couple of minutes later, couple more revs and dropped to 1300.
What do you think?…
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Pump off: drops to 2.6b immediately
After 10mins: 1.0b
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
![](https://emoji.tapatalk-cdn.com/emoji41.png)
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Been busy making a parcel shelf and prepping for my retro modern DIY audio install!
Will update build thread when it's done…
Anyway, cold pressure with the plug disconnected from wur should bei 1.35 to 1.65 bar. Engine should be stone cold.
Plug the WUR back in and run the engine (or put 12v to the WUR (I have 2 lengths of wire with crocodile clips on to do this). You should see the pressure climb until it levels off after a couple of minutes. At this point pressure should be 3.65 to 3.75 bar. As your engine has been modified you probably want the lower value. Turn the pump off and it should hold at about 1.9 bar for 10 mins, and after another 10 1.5 bar. This is basically your residual pressure. No residual pressure can give hot start problems.
Final test with pump running, engine off is system pressure, shut the tap off and you should get 4.5 to 5.1 bar. This proves the pump is doing what it should.
Hope that helps!
![](https://emoji.tapatalk-cdn.com/emoji6.png)
I’ll try those various tests.
And in the meantime, you may find this short video of mine interesting. It’s quite short but I was pleased!
Mk1 Golf GTi DIY Rear Parcel Shelf with speakers for less than £150! - YouTube
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
1. Right, let me just confirm the final pump test first: With pump running, engine off i get 4.65 bar. So am pretty sure my new pump is fine.
2. Back to the first test you specified: You said
“cold pressure with WUR plug disconnnected should be 1.3 to 1.65 bar. Engine should be stone cold”.
How do i conduct this ‘cold pressure’ test? The car is completely cold now (hasn’t been started for days and the pressure guage reads zero (with either the tap open or closed).
Do you mean:
start her up
with pressure guage tap open from stone cold
and 1.3 to 1.65 should be the initial reading before she warms up?.
3. This leaves what i’m assuming is the ‘warm pressure test’, which is as above but reconnect the WUR (still tap open) to hopefully get 3.6 to 3.7
4. And finally is the residual pressure test which is checking it twice, 10 mins apart each time. Think i’m clear on that one.
Just points 2 and 3 i need confirming. Ive looked in Haynes and i think thats it, but wanted to check please mate.
Tbh with the checks ive done, (even if a bit wrong), all i seem to get is full pressure of 4.65. Which make me suspect my WUR is faulty.
Im guessing that would explain my cold start issue as the system pressure is so high its preventing the air sensor plate from lifting and therefore no fuel is being sent to the injectors. If i’ve understood the system correctly…
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
3. Did the warm pressure test too, but with wur plugged in - but same result
Residual pressure also dropped too quickly but think thats for later…
So do we think its a duff WUR and if so best place to get a refurb kit?
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Anyway, I have bought wur and fuel distributor refurb kits from this chap on ebay - https://www.ebay.co.uk/str/missingpartsde
Good chap, decent instructions.
I'd suggest it is worth stripping the wur and giving it a thorough clean out.
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
FYI the WUR rebuild Kit from Germany for this later Model is almost triple the cost.
Ah well, still a cheap repair at £90!
Thanks as ever for all the knowledge sharing [mention]paceman [/mention]
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
There are also instructions for rebuilding the double diaphram wur (which is what you have). The instructions you get a very detailed, but an alternate version can't hurt.
Before you completely strip your WUR I'd check to see if the vac diaphram is ok. You should not be able to suck any air through the side outlet. If you can, you'll need to do the full rebuild. If you can't then I wouldn't separate the diaphram part of the wur, just remove the larger top half.
I'll get some pics of how mine is connected.
As you have to set warm first, I removed the bimetallic strip entirely, put the WUR back together and set the warm pressure. Put it all back in, and then set the cold pressure. Bit of a faff, but I couldn't adjust one without it impacting the other until I did that.
Worked my way through it using the instructions supplied rather than the one you mentioned in post #38.
Reconnected it to the pressure guage with the following results:
Cold start: 2.4 bar - this seems high as think it should be about 2.0
Warm start: 3.4 - ok i think
System pressure: 4.6 - ok i think
Residual pressure after 10 mins off: 1.0 - way too low
After 20mins: 0.5 - way too low
Overall good news in that she starts and runs which is great!
Cold start is a bit low but hopefully tolerable.
Residual pressure is way too low so going to tighten up the fittings (could here one hissing slightly) and hope that sorts it…
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
