Mk1 AWD project parts for sale
(In Topic #235801)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Ad%27s%20Golf%20visiting%20Camberley%202nd%20September%202018.jpg)
![CambridgeMarsRedMk1 in the usergroup ‘Regular’ CambridgeMarsRedMk1 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Mk2 Rallye complete running gear, Mk1 coilovers, Porsche brake kit etc.
All items are COLLECTION ONLY from Cambridge, Cambridgeshire (most parts) or outskirts
* FROM 11/7/22 UNSOLD PARTS WILL DISAPPEAR FROM THIS LISTING AND APPEAR ON EBAY AS FIXED-PRICE "BUY IT NOW" ITEMS *
DRIVETRAIN:
- 02M/Q 4wd gearbox to suit 4-cylinder engine (1.8T) including transfer box £100
- Starter motor for gearbox £20
- Epytec conversion mounts and bolts for gearbox, inc. new Mk1 Gold engine mount rubbers £200
- Gearshift mechanism and linkages for gearbox £25
- Brand new Valeo single mass flywheel and clutch to suit 1.8 20vt engine £150
MK2 RALLYE DRIVETRAIN PARTS (pains me to split this up)
- Mk2 Rallye propshaft, complete £300
- Mk2 Rallye rear axle beam £300
- MK2 Rallye floor where beam mounts £200
- Mk2 Rallye rear wishbones inc. hubs £350
- Mk2 Rallye ARB (with brackets – very rare) £175
- Mk2 Rallye rear driveshafts £120 EACH
- Mk2 Rallye full transmission tunnel, cut from dismantled vehicle £300
- Mk2 Rallye mounts for rear axle assembly £200
- Mk2 Rallye rear syncro differential (you could buy a syncro gearbox and make a simple AWD Mk1 using this) £125
- Haldex rear differential from Mk1 Audi TT (can apparently handle more power than syncro) £30
- Haldex conversion kit to be welded to rear axle (for Haldex diff fitting) £200
- All original brackets, nuts, bolts, washers from Mk2 Rallye for above £100
BRAKES:
- Mk2 Golf rear calipers and carriers (inc. slider kit for rebuild) £20
- Mk2 Rallye rear brake proportioning valve £50
- Mk1 Golf brake linkage bar with GTi servo and master cylinder and reservoir £70
- Porsche 986 4-pot calipers, adapters brackets, bolts, G60 280mm discs, braided conversion hoses (for front) £500
- Mk4 Golf rear calipers (need refurb) £5
SUSPENSION:
- FK adjustable coilover suspension with polyurethane bushes (unused I believe) £200
- Adjustable topmounts for front suspension £100
- Mk1 GTi ARBs £40 each / £70 pair
Last edit: by CambridgeMarsRedMk1
