Unbalanced rear brakes
(In Topic #233559)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/207925D4-50D5-4C80-AADB-03A3D368F828.jpeg)
![K-Pascu in the usergroup ‘Regular’ K-Pascu in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Im having problems with my mk1 cabriolet DX, rear brakes does not pass the annual technical inspection due to an incorrect balance between rear wheels braking (R/L). the handbrake works correctly and both wheels brake equally so it is a hydraulic problem or in the braking distribution.The first time the brakes are bled, they seem to brake correctly, but after a while they decompensate again and the fluid takes in air. It has been bled many times and the problem continues. Does anyone know what may be happening? Could it be the rear brake regulator?
Thanks a lot!
Thanks a lot!
Older cabriolets with the weight controlled proportional valve on the rear axle beam has been known to have issues.
If you have to re-bleed, then you have a leak somewhere.
If you have ruled out the MC, and the rear Wheel Cylinders, then you are left with brake lines, or the rear "compensator/proportional" valves.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/leech%20kr.jpg)
Regional Host NE
![nicci21paul in the usergroup ‘Paid Member’ nicci21paul in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![nicci21paul in the usergroup ‘Regional Hosts’ nicci21paul in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![nicci21paul in the usergroup ‘Local hero’ nicci21paul in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re:
Really not too difficult to sort surely in my opinionBriano1234 said
You could have a proportional valve that is wonky.
Sent from my SM-G960F using Tapatalk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Just had to fix mine after it failed the UKs MOT, no fluid obviously peeing out but enough leaking out of slave cylinder to contaminate shoes and mean no breaking.
The opposite side of the cylinder was seized. These were installed new about 20 years/40,000 miles ago.
The other side of the car looked OK but under the cylinder dust cover was full of fluid.
Over the years I've done 4 or 5 Golf/Jetta rear brakes and its always becasue of seized and/or leaking cylinders and never worn out shoes.
![Golf brake 1.jpg Golf brake 1.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1628366318/uploads/attachments/610ee5ed2704c.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/received_10212253851841257.jpeg)
![Kenneth Cartwright in the usergroup ‘Paid Member’ Kenneth Cartwright in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Kenneth Cartwright in the usergroup ‘Local hero’ Kenneth Cartwright in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
On the drive
Myvalver 89 GTi Grey mk2 16v
Regional Host NE
Re:
How much for the full setKenneth Cartwright said
drums can be a nightmare, check the adjusting slider is grabbing and that you can set them equally by hand before adding real brake force. as above get a set of new cylinders and measure the liners and internal of drum, see if since been bad they need changing, did this job 2 months ago, was a mare took 4 attempts to get within the MOT spec. Now have a full set up drums, liners, and cylinders sat in a box "just in case " for next cabbys MOT.
![](https://emoji.tapatalk-cdn.com/emoji848.png)
Problem persists, the right rear wheel brakes less than the other. my cabrio gli is from 1989 so it has the mk2 MC with the two rear brake adjusters in the MC. This has to be the problem, we have cleaned them with ultrasound but no luck either. I have realized that the regulators are not what they should be (533612151) but that they actually have mk3 ones (1H0 698 401). the first ones are very difficult to find so I will buy the second ones again as it seems that it can work with them.
![161GPV1181-10-1.jpg 161GPV1181-10-1.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1631781807/uploads/attachments/614303adcb5eb.jpg)
Thanks!
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/music.png)
![jakethepeg007 in the usergroup ‘Local’ jakethepeg007 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Thanks!
Regional Host NE
Early-1800 said
Have you had the drums off and had a look to see if anythings obviously amiss in there?
Yes, everything is new except the regulators, we have seen that one has a bent thread. The first braking works well but the next day it doesn't anymore, it seems to catch air bubbles
There is 2 types of wheel cylinder, the bigger 17mm one for cars with a rear brake system regulator and smaller 14mm cylinders for cars with out a regulator.
yes, 17,5 mm ATE. One side works perfectly every time. it is the other that little by little brakes less and coincides with the bent regulator.mark1gls said
Are both the rear wheel cylinders the same?
Thanks!
![WhatsApp Image 2021-09-22 at 14.21.51.jpeg WhatsApp Image 2021-09-22 at 14.21.51.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1632348455/uploads/attachments/614ba9265fe34.jpg)
![WhatsApp Image 2021-09-22 at 14.22.01.jpeg WhatsApp Image 2021-09-22 at 14.22.01.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1632348456/uploads/attachments/614ba9286a04a.jpg)
