Mechanical Pump Not Pulling Petrol
(In Topic #233768)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/image00002.jpeg)
![Viggymaster in the usergroup ‘Regular’ Viggymaster in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Sent from my SM-G973F using Tapatalk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
When the tank filler pipe rots (as they all do) and fills the tank with rust, debris and water the filter clogs and starves the engine of fuel. People then often shorten the pipe and/or remove the filter to stop this happening. Works OK until the fuel drops below length of the shortened pipe.
Or it could be that its still getting clogged as the tank is full of more rubbish than petrol
Under the back seat remove the inspection cover and remove the level sender and have a look see.
Open all windows and no electric torches, use gas safe led lighting. Open the fuel cap as well.
Re:
Ive removed the sender uni and had a look into the tank many times and its very clean in there. Ive tried many things to get it to suck the petrol up, ive attached extra hose to the sender to lengthen it, shortned and lengthened the outlet pipe and checked if it is clean and still nothing. Ive tried sucking the petrol up myself and nothing comes through.Early-1800 said
On carb engined cars the petrol is drawn via the outlet on the level sender fitted to the top of the tank. This outlet includes a plastic filter fitted on its end.
Does the outlet look like its been molested? When it fails to draw petrol and you remove the level sender is the pipe wet (i.e. it is 100% def certainly on your childs life) submerged in the petrol?Viggymaster said
When it is working if you remove the hose from the pump to the carb and crank the engine does it give good health spurts or a dribble (ooh err missus)
