Golf GTI Cabriolet 1988 1.8
Is the noise related to road speed?
its not retaliated to road speed
could it be the pump strainer being too close to the bottom of the tank?
i put £40 of fuel in it today thinking the noise was because it was low on fuel but it made no difference
If it's definitely coming from inside the fuel tank, which is where you've just been, I would suspect it's related to that. I would pull the lift pump again and take a look
i”ll let you know
thanks
Simon
On the drive
Myvalver 89 GTi Grey mk2 16v
How do I keep that pesky strainer attached while placing it in the tank?
Tie it up with string, then after you have it inserted clip the string and gently pull it out.
i have reduced the length of the pipe from in tank pump to sender
but today we went out in the cab, came back out and started up absolutely fine then cut out and would not restart
i had to have the drive of shame back (towed by my pals Touareg!)
i fitted the old old pump and it started up straight away so the new pump is buggered!
i got it from classic vow but am now nervous about buying another from them, should I get a second hand genuine one?
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=1993+vw+cabriolet+in-tank+fuel+pump&_sacat=0
I usually spent about 60 bucks for the in-tank pump.
i have ordered one from vw heritage
i have emailed them twice but still not had a reply!
one thing I did notice on the pumps is that the original one it’s 15mm inlet and the 2 new ones are 19mm
looking at the part numbers mine should be 19mm
any ideas?
Thanks again
after a 30 min drive I get home and turn it off, 15 mins later it will not start! It does eventually
any more help greatly appreciated
thanks
They have issues with cold solder joints on the relay contacts and an improper circuitry in some.
See page 5.
http://www.cabby-info.com/Files/Relays.pdf
my fuel pump relay is a Kracker 24.1400.20
is this right for my car?
i have searched eBay, classis vw and vw heritage and they are all different!
i can get one tomorrow from gsf which is 935VG0200 for £16
will this work?
help please
thanks in advance
Paul Hodson said
I fitted one last week from heritage, 321-906-059/G. Printed up with code 3.300.220. And says for 1.8 gti engines, not sure how it differs from other ones but cost me £61 delivered. Mines a 1990 cabby.
That seems to be incorrect, there are 2 relays on the Digifant, and both the relays are robust and well I have over 500K combined on my cabbies with out needing a replacement.
This is the standard Digifant fuel injection power supply relay which is the standard 40amp 53 relay.
VW #141951253B
Meyle #1009510001
Then there is the fuel pump relay, that is
VW #191906383C
KAE #2.400.140
So I don't know which one you are referring too.
The CIS system dosen't use those styles of relays, and I think some of the confusion is that there is previous posts that refer to CIS and not Digifant.
