Golf GTI Special '83
(In Topic #232662)
I would love to be corrected if I have the wrong information, or if you can tell me some more about this car.
A little warning - I'm not a mechanic. I do enjoy spending time in the garage, and I have done basic repairs like switching brakes and such, but that's it. So this will be quite interesting and a steep learning curve I guess.
My plan is to strip the car completely in pieces, sandblast / prime the body and then get it back in my garage to start working on it. There will be a lot - like A LOT of welding needed, and at this point (I'm on day 4 now) I'm actually a bit worried if it is at all possible, but I haven't given up yet.
I'll share some pictures from the first days and keep you updated along the way.
Picking up the car:
The engine bay when picking it up:
This is after day three. I started in the back and work my way taking out the interior.
I did continue the work today and I've stripped most of the dashboard, emptied the coolant to remove the fan/heater, removed the roof lining to uncover the sunroof.
The roof has some serious rust because the car has been standing outside for like 20 years, so I'm pretty sure it has to be replaced. I was trying to figure out a way to remove the sunroof installation today. As far as I can tell the only way is to cut the welds. I'd love to hear some thoughts on that.
I'm hoping to be able to remove the engine this weekend. Something I've never done before - but I'm taking a lot of pictures, putting parts in boxes, screws in plastic bags and labelling as much as possible.
Thats it for now - wish me luck
This is the rust in the roof. The reason is that water has been trapped in the sunroof padding for 20 years. I guess.
This is the driver (left) side. It is not shown in this picture but both floors needs to be replaced.
stichill99 said
Best of luck.Looks like a big job but nothing that has not been done many times before!
Thank you! I'm keeping fingers crossed that everything will work out fine in the end, but it is definitely a big job
The doors are in somewhat bad shape, so right now I'm not really sure if I should spend money on trying to sandblast them together with the rest, or if I should just look for replacements. But they are at least off
Thank you The sunroof is not even close to open. Completely stuck. So I'm trying to figure out what to do. There is quite some rust in the roof as there's been water laying in the sunroof mechanics for years. The sunroof part is most likely not repairable, so maybe the best alternative is to replace the whole roof. If possible to get hold of one. Another alternative is to remove the sunroof completely but I would very much like to avoid that option.Hef355 said
Good luck mate! What does that sunroof aperture look like? Will it open?
Water got in behind my soonroof seal and I got some rust but luckily mine isn't too far gone. You'll need to replace the whole roof because if you weld in a panel the whole thing will warp and look rubbish. If you somehow managed it you'd need a lot of filler to match the contour of the roof without leaving a witness.
It's not a Campaign literally, but it is a "Golf GTI Spesial". It was a campaign edition in Norway in '83 with Avus Snowflake rims, leather steering wheel, onboard computer, extra fog lights in the front, green tinted windows and sunroof as an optional addon.Hef355 said
Ah mate that doesn’t sound good sadly! The inside is probably rotten! I think if it’s not a campaign, which it’s not I think I would remove the whole roof section and replace it with a tin top. I have a good roof panel if you decide to go down that route. Very very rare to find a tim top roof these days
Not sure how it differs from a Golf GTI Campaign? Except for the Pirelli rims?
But anyway - since it is kinda of a special car (the last batch from the factory) I would try to go the extra mile to get hold of a roof. Would it by any chance be the same sunroof as the '84 mk2?
tomsdubs said
Good to see another one being saved! You'll be a welding pro by the end of this one
I think you're 100% right. From what I can tell it's welded in 4 (or 5?) spots to the "outer roof", but replacing that part will probably be difficult to get perfect.
I think the sunroof aperture is structurally important to hold the profile of the roof, I think if you cut it out the whole roof would sag down really bad. What's it like trying to get spares in Norway? If you could find a donor car that has a decent roof that'd be perfect.
I found someone else who has done it:
https://www.vwwatercooled.com.au/forums/f13/mk1-golf-project-68816-3.html#post868858
It's not impossible to find, but the chance of finding a roof without the rest of the car is probably tricky. I did find a potential donor car (https://www.finn.no/car/used/ad.html?finnkode=205347543) for around £2100 and I've sent him an email asking for the condition on things like hood, doors, hatch and so on. Maybe it could be a good deal after all.
Thanks for the tip! I've been following a guy called Dan Chambers on Youtube and he is doing a project very similar to mine. He's been talking a bit about the roof and will most likely end up replacing it the same way.
Here is the playlist: https://www.youtube.com/watch?v=fXL8ple0o7c&list=PLW6s2hBFjAE5XFu3iYgYcynkaljPdlWMa
I've also started removing things from the engine bay and hopefully it won't be long before I can pull out the engine Keeping fingers crossed!
Thank you, and I agree - they doesn't look that bad. I think the reason may be as simple as they been protected from water. My theory is that most of the other rust is a result of the car standing outside and not in use for over 20 years, and the fact that the sunroof was not tight/fully closed so water could get in and stay there.tomsdubs said
Nice work mate, those inner wings are surprisingly good.
If I can get this back in working condition I would say anything is possible. At this point I'm seriously considering wether spending £1500 on sandblasting is the right thing to do. But still keeping fingers crossed
Apart from roof it all looks like normal old car rotten floor and sills. A bit of a weldathon but repair panels are available and it can be made good.
