Respray advice/opinion
(In Topic #228728)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/DE658344-1A53-404B-8A46-267E94B3ECCD.jpeg)
![BigAndy81 in the usergroup ‘Regular’ BigAndy81 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Hi All,
I've had my cabby in for a fairly major cosmetic overhaul of late- I put the car in with the local VW specialist who's looked after the car the last few years, and agreed he'd manage the respray - as they haven't a paint shop and I've neither the space or skills to have undertaken the initial strip/investigation etc and i've a good relationship with them.
It's back and we're going to go over it together on Monday to check for snags, but as I know where it's being kept I just popped up to have an initial look. There's a few things i've spotted- most noticeably, there's a spot on one panel where the paint has 'pooled' slightly in the channel for the wasitline trim, so you see a couple of drips.
BUT- This is the first time I've had a car go through this process so I'm interested- how perfect should I expect it to be? For context, it's been quoted at what I believe is a fair level, certainly not cheap and cheerful.
The wasitline section I mentioned above feels a no brainer, but what about things the recessed panel edges in the shut lines etc, should they be perfect in your opinion? And what should I double check on Monday?
In hindsight I'd perhaps not have done it this way if I did it again, as I've not had any direct dealings with the paint shop, but it is what it is and I just want to make sure I feel it's fair all round.
I appreciate this might be a slightly subjective question, but any views are useful/welcome!
thanks
There shouldn't be any drips or runs or pooling in the paint on the waist line.
However even for a cheap blast over if a non expert like yourself can spot sagging and running drip issues I'd say its not fit for purpose and needs sorting.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/received_10212253851841257.jpeg)
![Kenneth Cartwright in the usergroup ‘Paid Member’ Kenneth Cartwright in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Kenneth Cartwright in the usergroup ‘Local hero’ Kenneth Cartwright in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
At the very least mark each section and photograph… send to the painters to go over the areas again..
we do occasionally miss a bit, and you are within rights to have it put back as good as possible.
Early-1800 is correct you get what you pay for i'm afraid., and it sucks .
I've had to travel 30- 60 miles to get correct paints for door repairs, the paint readers are pants at times. So changing painter would be more hassle …
On the drive
Myvalver 89 GTi Grey mk2 16v
