Scared of pot holes
(In Topic #225459)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_1732.jpg)
![okmate in the usergroup ‘Local’ okmate in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Is there any shocks or springs that can improve the stock ride ?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/whip3.png)
![the_whip in the usergroup ‘Old timer’ the_whip in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Have you checked your dampers & top mounts? Do you have stock springs or lowered?
After I got mine sorted I was aiming at pot holes, just because it was so nice not to have the bang going over them.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
I know that feeling. Mine turned out to be worn items rather than wrong items.
Thanks pal their stock i believe, what would you change first?
!00%paul_c said
I would definitely change the worn-out components.
I would check the fronts first. You should be able to see the if the top mounts are okay. Briano has a good guide on it: https://www.volkswagenownersclub.com/threads/replacing-front-struts-and-mounts.32171/
I think the dampers have to come out to check them properly. Push the piston all the way in and watch how long it takes to come up. Something like this should give you an idea:Briano1234 said
This is a bad mount:
Good mount Bad mount .
https://www.youtube.com/watch?v=ITm6817bI6E
Also, check your ride height against pictures of other cars (same type e.g.cabi) with stock suspension.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
The tiny avatar pic is definitely not stock height, can you post a bigger pic? Or measure it (eg from centre of wheel to the wheelarch) for comparison.
![IMG_2587.JPG IMG_2587.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593148680/uploads/attachments/5ef585075af80.jpg)
![IMG_2586.JPG IMG_2586.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593148686/uploads/attachments/5ef5850d9a7df.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/25591967_881758848664147_2415209317461727066_n.jpg)
![TBigJohn in the usergroup ‘Old timer’ TBigJohn in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![thumbnail_IMG_1858.jpg thumbnail_IMG_1858.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593171854/uploads/attachments/5ef5df8de57e9.jpg)
New inserts, top bearings, and GTI springs on a 92 Clipper. 195/50/15 tyres.
paul_c said
For a non-GTI that's definitely lowered. You need to measure it and compare.
Thanks mate will do, these are 15 inch wheels if that makes a difference
In my experience even standard cars driven carefully give the front suspension a workout with state of roads and speed humps etc. Check the dampers are still working and bump stops are intact.
![mk1cabro13.jpg mk1cabro13.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593248774/uploads/attachments/5ef70c0424560.jpg)
okmate said
Thanks for all your help guys I really do appreciate it' I know nothing about the coilovers or suspension ride height so will shortly measure the distance from the floor to the wheel arch, is there a way to determine the ride height so I could change the front first?
You need to also measure centre of wheel to wheel arch. Get some pics up of the suspension and someone will be able to advise if its standard or coilovers or looks totally worn out
![IMG_2605.JPG IMG_2605.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365320/uploads/attachments/5ef8d347775b2.jpg)
![IMG_2606.JPG IMG_2606.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365323/uploads/attachments/5ef8d34a74ce6.jpg)
![IMG_2607.JPG IMG_2607.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365326/uploads/attachments/5ef8d34d4596b.jpg)
![IMG_2608.JPG IMG_2608.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365329/uploads/attachments/5ef8d3503dcc2.jpg)
![IMG_2609 (1).JPG IMG_2609 (1).JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365331/uploads/attachments/5ef8d352bc096.jpg)
![IMG_2609.JPG IMG_2609.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365334/uploads/attachments/5ef8d35597d63.jpg)
![IMG_2610.JPG IMG_2610.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365337/uploads/attachments/5ef8d35814186.jpg)
![IMG_2611.JPG IMG_2611.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365339/uploads/attachments/5ef8d35af35a6.jpg)
![IMG_2615.JPG IMG_2615.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365342/uploads/attachments/5ef8d35d514f7.jpg)
![IMG_2618.JPG IMG_2618.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365344/uploads/attachments/5ef8d35fc61c5.jpg)
![IMG_2619.JPG IMG_2619.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365347/uploads/attachments/5ef8d3623b385.jpg)
![IMG_2620.JPG IMG_2620.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365349/uploads/attachments/5ef8d364944d5.jpg)
![IMG_2622.JPG IMG_2622.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1593365352/uploads/attachments/5ef8d3672a44f.jpg)
Rears look pretty standard springs or dampers.
I'm not sure what the standard ride heighst are and haven't got easy access to my Cabrio at the moment to check mine, but don't look that lowered as prev said.
Top mounts look worn and stretched.
if I feel potholes that thud through the car will the top mounts do anything to better the ride,
as i said before pal havent got a clue how to check the springs/struts or mounts
