1983 Mars Red Gti
These also arrived today so engine can go to the machine shop.
There is a lot more gubbins on that than the one I had, but yes, you should be able to remove it all. You will likely need to swap over the linkages from the current one so that it will hook up properly. You'll also want to blank off that large vacuum pipe, and open up the inlet manifold to match the throttle body.Gaz343 said
Throttle body arrived today, can anybody confirm that i have the correct one, I assume that i can remove the switches.
Before:
After:
My Audi one is missing the small vac take off, but I'm just going to put a T piece in somewhere to cater for that.
Drilled and tapped the port where the vacuum fits and made a sleeve to screw in the same dimensions ans the original
Finished job with the idle screw fitted.
fitted the crankshaft which didnt need grinding, just a polish.
Will build the pistons and con rods tomorrow and install.
In my haste to make progress i managed to break a piston ring, no excuses just out of practice, about 25 years since i last built an engine.
Keep the pics coming
Will be nice to see the sunroof gone!
Have owned :-
Mk1, Mk2, Mk3, Mk4
Bugs, Buses, Type 3
Porsche 911T '71
Mk1, Mk2, Mk3, Mk4
Bugs, Buses, Type 3
Porsche 911T '71
Not a huge amount of progress this week, got the car on the rotisserie so i can get a good look underneath, i don't think its too bad.
Also got the head back on Friday.
Hopefully start some welding next week.
In the meantime been getting some parts ready to refit to the engine.
My scirocco 16v caliper carriers also arrived today
No rust whatsoever on the inner sill, there was no need to cut the panel out, i could have just repaired the holes, passenger side will be staying put.
New sill tacked in place.
Progress on the sunroof replacement panel, made some additional roof braces to assist with shape and stiffness.
Replacement panel now fitted, some panel beating work still to do.
When i first got the car i was shocked with the rust, but the the roof was really the only issue, everything else seems quite easily reapairable.
Also got the sill welded, just to clean up with the grinder now.
Also cut into the rear wings to see how much needs to be replaced, I have inner and outer repair panels that came with the car, only going to replace the minimum amount of steel but whats the best area to make the join ?
